patroddy Posted November 26, 2015 Report Share Posted November 26, 2015 Right I've currently got my central locking apart on my boot and I've got a few questions about the wiring.I've got the plug below labeled as wire 1(grey) and wire 2(green) These connect to the white box below which actuates the locking mechanism. My question is - Are the two wires both pulse wires? so if where connected to a latching relay as set and reset would they operate the relay correctly?THANKSPAT Quote Link to comment Share on other sites More sharing options...
Skezza Posted November 27, 2015 Report Share Posted November 27, 2015 It might be worth explaining your issue mate? Your boot CL packed up? You replaced the mech? I'm pretty sure both are pulse wires yes. Quote Link to comment Share on other sites More sharing options...
carrera-gt Posted November 27, 2015 Report Share Posted November 27, 2015 Simple relay flip flop with two timer relays, one locks it the other ulocks it, test lamp is the best way to test the system you should connect the lamp between green and grey and see it light briefly when locking and unlocking. Quote Link to comment Share on other sites More sharing options...
cj1 Posted December 4, 2015 Report Share Posted December 4, 2015 Simple relay flip flop with two timer relays, one locks it the other ulocks it, test lamp is the best way to test the system you should connect the lamp between green and grey and see it light briefly when locking and unlocking.Or use a multimeter if you have one... Quote Link to comment Share on other sites More sharing options...
carrera-gt Posted December 6, 2015 Report Share Posted December 6, 2015 Multimeter is not the best tool for this some low cost meters won't react to a short voltage pulse which is why I suggested the test lamp. Quote Link to comment Share on other sites More sharing options...
cj1 Posted December 6, 2015 Report Share Posted December 6, 2015 Multimeter is not the best tool for this some low cost meters won't react to a short voltage pulse which is why I suggested the test lamp.True! Just suggesting an alternative if they have one! Â Quote Link to comment Share on other sites More sharing options...
Skezza Posted December 6, 2015 Report Share Posted December 6, 2015 Oscillator Quote Link to comment Share on other sites More sharing options...
patroddy Posted December 6, 2015 Author Report Share Posted December 6, 2015 i got it solved, and its all for a boot popper that works from the outside of the car but reacts via the central locking, if anyone is interested in seeing the circuit diagram ill give it a share Quote Link to comment Share on other sites More sharing options...
carrera-gt Posted December 7, 2015 Report Share Posted December 7, 2015 Please share, always good to have new ideas Quote Link to comment Share on other sites More sharing options...
Skezza Posted December 7, 2015 Report Share Posted December 7, 2015 Video of how it works would be good. Quote Link to comment Share on other sites More sharing options...
patroddy Posted December 9, 2015 Author Report Share Posted December 9, 2015 Yer thats no problem, i shall get a video and some photos and post them up Quote Link to comment Share on other sites More sharing options...
