Nathan94 Posted January 18, 2014 Report Share Posted January 18, 2014 Just got a set of xenon headlights, but one of the lights has a damaged lens, is the standard light lens the same as the GTI so I could swap them over? Quote Link to comment Share on other sites More sharing options...
Defcon5 Posted January 18, 2014 Report Share Posted January 18, 2014 You mean you have a set of GTI headlamps?I very much doubt you can change the glass, and are you going to install sidelights where your indicators currently are? Quote Link to comment Share on other sites More sharing options...
Nathan94 Posted January 18, 2014 Author Report Share Posted January 18, 2014 Going to put the sidelights where the indicators are in the GTI headlight, got them for a bargain price, but the drivers side glass is peeling at the top of the light, so I was wondering if I could use my old lights to repair it or buy a new lens? Quote Link to comment Share on other sites More sharing options...
jon_273 Posted January 18, 2014 Report Share Posted January 18, 2014 The GTI lenses can't be separated by melting the glue like you can with the standard lamps, so I'm not sure how you could use your standard lamps to repair the GTI ones.You can buy a new headlamp casing but according to this forum they cost around £300! Quote Link to comment Share on other sites More sharing options...
Nathan94 Posted January 18, 2014 Author Report Share Posted January 18, 2014 Ouch, well I only paid £50 for the pair and one is fine. It looks like the laminate is peeling at the top, I was thinking could a wet and dry then polish cure it then maybe a bit of light black laminx to hide it? Quote Link to comment Share on other sites More sharing options...
GeoffD Posted January 18, 2014 Report Share Posted January 18, 2014 try buying just the light casing from europarts it may well be cheaper. geoff 1 Quote Link to comment Share on other sites More sharing options...
jon_273 Posted January 18, 2014 Report Share Posted January 18, 2014 I'm sure you could wet sand it to remove all the plastic coating, and them just machine polish the exposed polycarbonate surface. 1 Quote Link to comment Share on other sites More sharing options...
Nathan94 Posted January 18, 2014 Author Report Share Posted January 18, 2014 I'll give that a go then dirt and I can't see the headlight housing on euro car parts Quote Link to comment Share on other sites More sharing options...
GeoffD Posted January 18, 2014 Report Share Posted January 18, 2014 no, I had to order mine, so ring them up. mine was not for the gti mind. geoff Quote Link to comment Share on other sites More sharing options...
Defcon5 Posted January 19, 2014 Report Share Posted January 19, 2014 try buying just the light casing from europarts it may well be cheaper. geoffI doubt ECP will stock them Quote Link to comment Share on other sites More sharing options...
