r0ssi_tdi Posted January 16, 2014 Report Share Posted January 16, 2014 After filling up the Arosa last night i drove home and when i pulled up i realised the ABS light was on. So, drove straight back out again and surprise surprise, the ABS is no longer working.Is this a specialist job to get the car looked at, or can i sort it myself?Thinking il go and get it diagnosed if its tricky then just buy the parts myself. I wonder if this has anything to do with the light thud ive been getting from the front right wheel on every rotation... Quote Link to comment Share on other sites More sharing options...
Rich Posted January 16, 2014 Report Share Posted January 16, 2014 Read the codes.Fix the fault.Clear the codes.Done. Quote Link to comment Share on other sites More sharing options...
Skezza Posted January 16, 2014 Report Share Posted January 16, 2014 I might be completely wrong on this, and no doubt Rich (having already commented on this thread) will do his utmost to make me look a prat .... but I was told previously that most common causes of ABS light coming on were:ABS Sensors not reading the same speed (need to find out which has broken then replace, it may tell you when you scan though) or has failed altogether.Low Brake FluidWorn wheel bearings can damage sensor apparently. Not 100% on this one.There may be more, so it's worth getting it scanned asap, although in the short-term it might be worth trying to do an emergency stop or something, perhaps at 30 or 40 and seeing if it goes out. I assume your brake servo's are still working right? I don't know if the computer automatically disables ABS if a fault code is logged you see... Quote Link to comment Share on other sites More sharing options...
r0ssi_tdi Posted January 16, 2014 Author Report Share Posted January 16, 2014 Thanks for the replies chaps. I've got an OBD fault reader that I used to use on my Clio, will that work? If so where do I plug it in on an Arosa? Quote Link to comment Share on other sites More sharing options...
Skezza Posted January 17, 2014 Report Share Posted January 17, 2014 Thanks for the replies chaps. I've got an OBD fault reader that I used to use on my Clio, will that work? If so where do I plug it in on an Arosa?MK2? Under the ashtray. Quote Link to comment Share on other sites More sharing options...
r0ssi_tdi Posted January 17, 2014 Author Report Share Posted January 17, 2014 Well i plugged in my OBD scanner to check the fault and its not showing... gonna have to take it somewhere that can read the fault!Anyone got one that would work in the midlands anywhere? Quote Link to comment Share on other sites More sharing options...
Skezza Posted January 17, 2014 Report Share Posted January 17, 2014 I'm in Stoke. No reason why it shouldn't work although there is such a thing as an ABS Scanner, I don't know if they're any different to a normal OBD2 scanner though. Quote Link to comment Share on other sites More sharing options...
jon_273 Posted January 17, 2014 Report Share Posted January 17, 2014 The generic OBD2 scanner he used probably only reads the engine controller. The ABS fault lives in the ABS controller so you need something that can read that. Quote Link to comment Share on other sites More sharing options...
r0ssi_tdi Posted January 18, 2014 Author Report Share Posted January 18, 2014 Ah ok... Any recommendations on where to get it looked at? I'm based in Warwickshire... I hear Stealth racing in southam have a good reputation? Quote Link to comment Share on other sites More sharing options...
jon_273 Posted January 18, 2014 Report Share Posted January 18, 2014 They should be a good starting point. And you can get it remapped while you're there! Quote Link to comment Share on other sites More sharing options...
r0ssi_tdi Posted January 18, 2014 Author Report Share Posted January 18, 2014 Haha! I like your thinking mate ;-) Quote Link to comment Share on other sites More sharing options...
Skezza Posted January 20, 2014 Report Share Posted January 20, 2014 Ahh, that makes sense. I use a VAGCOM for any major diagnostic work. That scans ABS controller, air bag controller, pretty much everything. Quote Link to comment Share on other sites More sharing options...
