ABS light on and no ABS
r0ssi_tdi
After filling up the Arosa last night i drove home and when i pulled up i realised the ABS light was on. So, drove straight back out again and surprise surprise, the ABS is no longer working.
Is this a specialist job to get the car looked at, or can i sort it myself?
Thinking il go and get it diagnosed if its tricky then just buy the parts myself. I wonder if this has anything to do with the light thud ive been getting from the front right wheel on every rotation...
I might be completely wrong on this, and no doubt Rich (having already commented on this thread) will do his utmost to make me look a prat :).... but I was told previously that most common causes of ABS light coming on were:
  • ABS Sensors not reading the same speed (need to find out which has broken then replace, it may tell you when you scan though) or has failed altogether.
  • Low Brake Fluid
  • Worn wheel bearings can damage sensor apparently. Not 100% on this one.
There may be more, so it's worth getting it scanned asap, although in the short-term it might be worth trying to do an emergency stop or something, perhaps at 30 or 40 and seeing if it goes out. I assume your brake servo's are still working right? I don't know if the computer automatically disables ABS if a fault code is logged you see...
Thanks for the replies chaps. I've got an OBD fault reader that I used to use on my Clio, will that work? If so where do I plug it in on an Arosa?
MK2? Under the ashtray.
I'm in Stoke. No reason why it shouldn't work although there is such a thing as an ABS Scanner, I don't know if they're any different to a normal OBD2 scanner though.
Ahh, that makes sense. I use a VAGCOM for any major diagnostic work. That scans ABS controller, air bag controller, pretty much everything.
