Mini_ash Posted December 20, 2013 Report Share Posted December 20, 2013 i know that you can fit corsa shocks on the back but im thinking it will be to soft is they anyway you can fit short corsa shock on the back so will be stiff still ??? Quote Link to comment Share on other sites More sharing options...
James827 Posted December 21, 2013 Report Share Posted December 21, 2013 yes, i had them on mine. i had standard ones and it was VERY soft. maybe coil-over ones would be better use lupo bump-stops or double them up or wheel will hit top of arch! Quote Link to comment Share on other sites More sharing options...
Keelan Posted January 3, 2014 Report Share Posted January 3, 2014 What spring did you use Quote Link to comment Share on other sites More sharing options...
James827 Posted January 5, 2014 Report Share Posted January 5, 2014 standard uncut TA technix coil over rear spring. had to put spring in and jack up the axle to get in the Shock and the spring compresses a little. wasent to uncomfy i must say. but that was probably due to standard shocks. Quote Link to comment Share on other sites More sharing options...
north wales loop Posted January 14, 2014 Report Share Posted January 14, 2014 need coilover shocks. standard ones waaay too soft Quote Link to comment Share on other sites More sharing options...
Mini_ash Posted January 14, 2014 Author Report Share Posted January 14, 2014 will the coilover shocks still fit since they will be shorter then the standard corsa shocks Quote Link to comment Share on other sites More sharing options...
rob_pandy Posted January 15, 2014 Report Share Posted January 15, 2014 have any one fitted corsa rear coilovers, the type with the spring is around the damper like thesehttp://www.ebay.co.uk/itm/Vauxhall-Nova-Corsa-Gaz-adjustable-rear-coilovers-with-springs-/190994933277?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item2c782f661dmight give a better ride 1 Quote Link to comment Share on other sites More sharing options...
James827 Posted January 15, 2014 Report Share Posted January 15, 2014 i would like to think they fit nice and give you lows and comfort, but my only concern would be the spring seat etc being too wide and rubbing against wheels Quote Link to comment Share on other sites More sharing options...
north wales loop Posted January 16, 2014 Report Share Posted January 16, 2014 I thought of using these but opted for custom springs and corsa coilover shocks. don't think the rear turrets of a lupo could take the hammering either tbh Quote Link to comment Share on other sites More sharing options...
