jadelauren Posted February 20, 2013 Report Share Posted February 20, 2013 Hello,I'm going to explain this as easily as I can I have had this issue for a while now, when I indicate left when exiting a roundabout or going round a bend (when my steering wheel is turned whilst I'm moving) my left hand indicator seams to flash but double as quick as it should and my inside indicator does the same as well as the ticker. This also makes my stereo sound waver and jiggle in time with the defective light ticking (if that makes sense).Could this be the sign the bulb has blown or is there a wiring defect do you think? As I was following a Y reg Polo not too long ago and his car did exactly the same when indicating left and I know that Polo's and Lupo's are nearly identical when it comes to maintenance and repairs.Has anyone had this issue before or have an inkling what to do? Sorry if its really simple and obvious, its just been bugging me for a while now. Quote Link to comment Share on other sites More sharing options...
Pete91 Posted February 20, 2013 Report Share Posted February 20, 2013 Are all the bulbs working? Quote Link to comment Share on other sites More sharing options...
jadelauren Posted February 20, 2013 Author Report Share Posted February 20, 2013 Are all the bulbs working?Yeah they are Quote Link to comment Share on other sites More sharing options...
GTIChris Posted February 20, 2013 Report Share Posted February 20, 2013 Mine does this first thing in the morning when its cold but after a while its ok as if the interior temperature has an effect on it, I just gently ease back on the stalk and it works ok Could do with investigating it really. Quote Link to comment Share on other sites More sharing options...
m1cr08472 Posted February 21, 2013 Report Share Posted February 21, 2013 If the blubs are OK then the stalk needs replacing. Mine used to do it but if I pressed the stalk into position really hard it would work. Common fault I believe. 1 Quote Link to comment Share on other sites More sharing options...
