grazo22 Posted August 4, 2012 Report Share Posted August 4, 2012 RoightIt's only 4 weeks until I get Lemmy Lupo back.1 problem which has bugged me and I would like to get sorted is the revving. It's pretty simple to explain, you rev the car, take your foot off the pedal and there is a delay before the revs die down and they die slightly slower than usual. I've got a Bosch Lambda sensor on the car which I got from a part supplier, certainly the correct one.Speaking to a pal in the garage the other day he said that could be the reason and they a genuine lambda sensor will react quicker even if they are made by the same people (Bosch)Just wondering if anyone has any experience of this or if there is anyway I would be able to change this on VAG-COMMerci Quote Link to comment Share on other sites More sharing options...
lupo1.0se Posted August 5, 2012 Report Share Posted August 5, 2012 It ironic your talking about Lamba sensors, i having mine replaced at it is intermittenly faulty. It will be replaced with a geniue like for like. I will let you the results. Quote Link to comment Share on other sites More sharing options...
Defcon5 Posted August 5, 2012 Report Share Posted August 5, 2012 If the OEM is Bosch and you have a Bosch one, I cant see there being any difference between them. The ony difference will be the box! Quote Link to comment Share on other sites More sharing options...
jon_273 Posted August 5, 2012 Report Share Posted August 5, 2012 Have you compared it with any other lupo/arosas and is it noticeably slower? If it's similar, then i'd say that it is just a characteristic of a drive-by-wire throttle. Quote Link to comment Share on other sites More sharing options...
grazo22 Posted August 5, 2012 Author Report Share Posted August 5, 2012 Have you compared it with any other lupo/arosas and is it noticeably slower?If it's similar, then i'd say that it is just a characteristic of a drive-by-wire throttle.I've compared it to my friends which is like any other car, up and down, no delay, same as my golf.There is a noticeable delay. I wouldn't have thought there would be a difference but the delay is poop when trying to change gear with gusto as the revs don't drop enough to sync up correctly Quote Link to comment Share on other sites More sharing options...
jon_273 Posted August 5, 2012 Report Share Posted August 5, 2012 If your sport is a 2000 model it might have a cable throttle. Maybe something is sticking slightly on the throttle body? Quote Link to comment Share on other sites More sharing options...
grazo22 Posted August 6, 2012 Author Report Share Posted August 6, 2012 She's a cable alright! Tried 2 different throttle bodies which work find on other lupos. All cleaned frequently so no sticking Quote Link to comment Share on other sites More sharing options...
