Okay so I decided to take some pictures through the process of my discreet boot build.
Push seats forward and remove boot liner...
Insert 2 pieces of timber for false floor struts...
Use silicone to secure the struts in as they hold it very strong but is also cleanly removable by force if needed (useful if restoring car back to original spec.)
Place boot liner on a piece of 12mm MDF. Use this rather than plywood as it is dense and cusions sound frequency better. Alterations must be made to the template, If you just draw round the liner it will not fit*
Use a jigsaw/coping saw or other various woodworking tools to cut out your base...
Once base is cut out, measure to the centre using a steel rule or other straight edge.
Mark out a circle using compass for the sub woofer to be mounted in...
Test fit your base then finish in desired material.
I decided to trim mine in Red leatherette :)
Will upload rest of the build pictures tomorrow along with finished product pictures.
If you are wanting one of these but do not want the hastle of making your own i can supply them for...
£30.00 - plain cut MDF base.
£40.00 - Carpet, Black/Grey.
£45.00 - Leatherette colour of your choice.
