dj_lupz Posted June 23, 2012 Report Share Posted June 23, 2012 The cars running fine and not over heating but the fan doesn't seem to be kicking in.Can someone possiable give me a tick list to check off of possiable issues?Cheers guys. Quote Link to comment Share on other sites More sharing options...
Defcon5 Posted June 23, 2012 Report Share Posted June 23, 2012 If its not overheating whats the problem? If it doesnt reach the trip temp it wont come on.Power the fan directly and see if it works. Quote Link to comment Share on other sites More sharing options...
dj_lupz Posted June 23, 2012 Author Report Share Posted June 23, 2012 Coz it did over heat when it went for the mot. But I thought I knew what ye issue was. Quote Link to comment Share on other sites More sharing options...
RobG Posted June 23, 2012 Report Share Posted June 23, 2012 Is it seized up? Eg can you spin it by hand. Quote Link to comment Share on other sites More sharing options...
dj_lupz Posted June 23, 2012 Author Report Share Posted June 23, 2012 yeh spins by hand. Quote Link to comment Share on other sites More sharing options...
CasperGTI Posted June 27, 2012 Report Share Posted June 27, 2012 Fan switch on the radiator passenger side. that's what switches it on. Iirc it's at 97 degrees. Quote Link to comment Share on other sites More sharing options...
dj_lupz Posted June 28, 2012 Author Report Share Posted June 28, 2012 Tested the fan today and it works, so it could be the thermostat?And it over heated yesterday in a traffic jam.Any other help/advice?"John" - Is that the plug which is located below the top hose? Quote Link to comment Share on other sites More sharing options...
Defcon5 Posted June 28, 2012 Report Share Posted June 28, 2012 If it were the stat it would overheat all the time, not just when stationary.AFAIK there is only one sensor on the rad, which is the fan switch, on the right hand side of the rad as you look at it from in front of the car Quote Link to comment Share on other sites More sharing options...
dj_lupz Posted June 29, 2012 Author Report Share Posted June 29, 2012 Oright well it's ok went there is air getting to it and I've had it sat on drive running with no issues. But it didn't like the traffic jam lol. Ye I know the sensor your on about. This one ^ Do you think it needs replacing? Quote Link to comment Share on other sites More sharing options...
Defcon5 Posted June 29, 2012 Report Share Posted June 29, 2012 Sounds like it to me. Quote Link to comment Share on other sites More sharing options...
dj_lupz Posted June 29, 2012 Author Report Share Posted June 29, 2012 Part number any one? Quote Link to comment Share on other sites More sharing options...
