tuggy Posted February 26, 2012 Report Share Posted February 26, 2012 Hi guys,just bought a 1.2 fox and have a couple of questions.I have the urban model with central locking and it has the flashing led in the door,does this mean it has an alarm? Also can i use the ross tech software on this car? and where is the connection point? and finally i am missing the screw in tow eye for the front,are all vw ones the same? if so i can get one from ebay.thanks for any advice.tuggy Quote Link to comment Share on other sites More sharing options...
Silver! Posted February 26, 2012 Report Share Posted February 26, 2012 Not sure if all the tow eyes are the same, but you should be able to pick one up from a local breaker. Must be loads of MK3\4 Polos MK3 Golfs etc breaking nowadays.Lupo\Arosa connection is under the ashtray check there. If not there check for removable panels around the steering colum. Quote Link to comment Share on other sites More sharing options...
RobG Posted February 27, 2012 Report Share Posted February 27, 2012 The flashing LED usually just indicates the immobiliser is active, my lupo doesn't have an alarm but does have the flashing LED (and the passat does have an alarm, and also has the flashing LED) Quote Link to comment Share on other sites More sharing options...
gazzm Posted February 27, 2012 Report Share Posted February 27, 2012 the flashing light is only immobilisor, no alarm fitted, towing eyes are all same threads as lupo/polo Quote Link to comment Share on other sites More sharing options...
