sinki106 Posted February 9, 2012 Report Share Posted February 9, 2012 getting into gears has always been that little bit stiff, but when i go to work and it has been rainning there is always a big puddle everytime i come out the other end the gears are so easy to change fromjust wondering if anyone knows why this is?is there a seal gone somewhere and it isnt holding any lube, i dont knoow what its isany help would be much appreciatedthanksdavid Quote Link to comment Share on other sites More sharing options...
Defcon5 Posted February 9, 2012 Report Share Posted February 9, 2012 Water freeing up the linkages slightly? Quote Link to comment Share on other sites More sharing options...
puggled Posted February 9, 2012 Report Share Posted February 9, 2012 If you lift up the gaitor inside the car has your grease turned into a big white crusty lump? Quote Link to comment Share on other sites More sharing options...
sinki106 Posted February 9, 2012 Author Report Share Posted February 9, 2012 Water freeing up the linkages slightly?i think that is what it is, but does that mean am besst replacing the linkagesIf you lift up the gaitor inside the car has your grease turned into a big white crusty lump?no that all seems fine Quote Link to comment Share on other sites More sharing options...
