3lward Posted January 29, 2012 Report Share Posted January 29, 2012 Had a quick search couldnt find my answers to the following questions:-1, how do you drop then change the PAS fluid?2. how to drop and change the Coolant? Quote Link to comment Share on other sites More sharing options...
James827 Posted January 29, 2012 Report Share Posted January 29, 2012 Coolant would be to disconnect Lower radiator pipes, and actually id just get it out and flush it out (radiator) and by flush just run water from a Hosepipe from the top of the radiator so it washes out any Kack in the radiator, and id do the same by running water through the header tank just to make sure its all Ungunked and working as it should. Never Done a PAS fluid change, but id just disconnect all the lines to the rack and the top of the reservoir and let it drain. I may just be dumb but i cant actually get the cap off my PAS tank?well i cant seem to twist it off or grip it properly. Quote Link to comment Share on other sites More sharing options...
3lward Posted January 30, 2012 Author Report Share Posted January 30, 2012 Sweet cheers mate.The pas top as a groove to put a screwdriver/thick knife in to screw it off. checked mine and its ****ing black! lol xx Quote Link to comment Share on other sites More sharing options...
HalfOfZero Posted January 30, 2012 Report Share Posted January 30, 2012 I had to fill up my PAS oil the other day, cap was jammed tight lol. Quote Link to comment Share on other sites More sharing options...
Derv Posted January 30, 2012 Report Share Posted January 30, 2012 I find a spanner handle undoes a hydraulic fliud cap easily.My experience is from other VAG cars, as my Lupo doesn't have PAS. But I remove the lower feed pipe to the pump to drain most of the old fuild out.You can slacken/remove the belt and turn the pump by hand to get the rest of the fluid out. Or immobilising the engine and cranking it over on the starter would probably be the lazy way.Use only green G 004 000 BTW. Quote Link to comment Share on other sites More sharing options...
3lward Posted January 30, 2012 Author Report Share Posted January 30, 2012 Whats the reasoning behind only using G 004 000? Quote Link to comment Share on other sites More sharing options...
3lward Posted January 30, 2012 Author Report Share Posted January 30, 2012 Also the car isnt taking the full 5L as it should, its taken about half, ive ran it till the fan come on, squezzed all possible hoses with the cap off and still not dropping? Quote Link to comment Share on other sites More sharing options...
