jabbles21 Posted November 21, 2011 Report Share Posted November 21, 2011 (edited) Wonder if anyone can give me some advice... Drove the car back from Uni, around 2 miles at about 11 oclock this morning and all was well. Then i drove it at around half 5 this evening, and the brakes/wheels are squealing like a piggy. It sounds like it's coming from the front nearside the most but may be wrong. The car was parked on the road between it being driven so i dont really get how it's done it all of a sudden? It does it all the time when moving, unless im braking when it seems to back off a little. I jacked the car up then briefly (i have limited resources here) and tried to wiggle the wheel, there is no play so i'm hoping it's not a wheel bearing.. I will try get the wheel off tomorrow to examine the disks and pads but I dont have a socket set at uni so i'm a bit stuck.. Anyone had this before? Solutions? Cheers, Jake. Edited November 21, 2011 by jabbles21 Quote Link to comment Share on other sites More sharing options...
Defcon5 Posted November 21, 2011 Report Share Posted November 21, 2011 Could be as simple as a stone stuck between the disk and pad Quote Link to comment Share on other sites More sharing options...
jabbles21 Posted November 21, 2011 Author Report Share Posted November 21, 2011 I'm hoping so Just dont see how it would have got there having been parked there for 6 hours haha.. unless it was literally as i parked up. Quote Link to comment Share on other sites More sharing options...
Defcon5 Posted November 21, 2011 Report Share Posted November 21, 2011 Can you hear anything when you spin the wheel with it in the air Quote Link to comment Share on other sites More sharing options...
jabbles21 Posted November 21, 2011 Author Report Share Posted November 21, 2011 Nopey. rolls fine, no crunches, grinds or play at all. Quote Link to comment Share on other sites More sharing options...
chansingh833 Posted November 23, 2011 Report Share Posted November 23, 2011 I had the same problem, turns out something was stuck between the pads and disc, get your pads off and look for dirty streaks on the disc and if so you'll need to change your discs and subsequently your pads! Don't try and hope changing the pads will solve your problem,been there done that loool! But yeah there pretty much nothing you can do without a few spanners...... Quote Link to comment Share on other sites More sharing options...
jabbles21 Posted November 23, 2011 Author Report Share Posted November 23, 2011 All sorted now! Reversed about 20m, then drove forwards and it's been fine, so it must've been something lodged in the back of the pad just getting pulled in when going forwards, bit of reversing and it popped out! Ideal! Thanks for all the advice Quote Link to comment Share on other sites More sharing options...
James827 Posted November 23, 2011 Report Share Posted November 23, 2011 i had this exact problem a week of two ago. stripped down the whole front brakes looking for faults but there was none. haha Quote Link to comment Share on other sites More sharing options...
