Landroverwolf Posted November 20, 2011 Report Share Posted November 20, 2011 HiIve got a 1 lite lupo with about 60000 miles on. Quite recently when it is started in the morning usually the tickover goes up and down from about 750 revs to about 1100 and then back down to 750 about once a second. When the car is warm it still does it slightly but not as pronounced.any ideas Quote Link to comment Share on other sites More sharing options...
Defcon5 Posted November 20, 2011 Report Share Posted November 20, 2011 Does your temp guage work properly? If it does, I would be eyeing up the EGR valve Quote Link to comment Share on other sites More sharing options...
lupo_jack Posted November 20, 2011 Report Share Posted November 20, 2011 I had this problem for ages and then eventually my car started to judder wilst driving and lost power. So i took into garage and i got my coolant temperatue sensor, spark plugs, ht lead set and ignition coil pack changed and the idle problem also stopped lol Quote Link to comment Share on other sites More sharing options...
adamsanders Posted November 21, 2011 Report Share Posted November 21, 2011 air leak after the air mass meter Quote Link to comment Share on other sites More sharing options...
CJ N Posted November 24, 2011 Report Share Posted November 24, 2011 check your leads Quote Link to comment Share on other sites More sharing options...
Landroverwolf Posted November 24, 2011 Author Report Share Posted November 24, 2011 thanks guysok temp guage works but seems a bit slow warming upupdate on the tickover it cut out on me today whilst going along pushed the clutch in to change gear and it just cut outwhat is the egr valvewhat is the air mass meterlandroverwolf Quote Link to comment Share on other sites More sharing options...
Defcon5 Posted November 24, 2011 Report Share Posted November 24, 2011 Lupos use a pressure sensor rather than the hot wire, so you cant really have an air leak after it!My Sport occasionally runs like a heap of crap, and it is always the EGR valve. Quote Link to comment Share on other sites More sharing options...
