mccrindle Posted August 10, 2011 Report Share Posted August 10, 2011 Hi guys basically when driving home from work the engine check light came up on dashboard but flashing rather than just staying light up and the car seemed to stutter. When plugged in to diagnostic it read Misfire on cylinder 4. Then looked at the spark plugs and the coil pack and leads but all was fine. Any ideas of advice would be appreciated. Going to replace spark plugs anyway just in case Quote Link to comment Share on other sites More sharing options...
Defcon5 Posted August 10, 2011 Report Share Posted August 10, 2011 Just see how it goes after you change the plugs - make sure you use the NGK ones though, a lot of people have had issues with other brands. Quote Link to comment Share on other sites More sharing options...
mccrindle Posted August 10, 2011 Author Report Share Posted August 10, 2011 yeah thats what i was gonna get, noticed people had trouble with others (: Quote Link to comment Share on other sites More sharing options...
Noncompusmentis Posted August 10, 2011 Report Share Posted August 10, 2011 I've got the same issues on my Lupo.http://forums.clublupo.co.uk/index.php?showtopic=81670The engine misfires, I can remove plug lead number 4 and the engine runs the same. BUT, the plug, lead and coil pack all produce a good clean spark. Quote Link to comment Share on other sites More sharing options...
parv Posted August 10, 2011 Report Share Posted August 10, 2011 I've got the same issues on my Lupo.http://forums.clublu...showtopic=81670The engine misfires, I can remove plug lead number 4 and the engine runs the same. BUT, the plug, lead and coil pack all produce a good clean spark.maybe injectors playing up because they use a waste spark system.... Quote Link to comment Share on other sites More sharing options...
Noncompusmentis Posted August 12, 2011 Report Share Posted August 12, 2011 maybe injectors playing up because they use a waste spark system....What's the best way that I can check that?This is the first time that I've had to tinker with a 'modern' engine, I'm used to messing around with aircooled flat fours!! Quote Link to comment Share on other sites More sharing options...
Defcon5 Posted August 12, 2011 Report Share Posted August 12, 2011 Dont mess with anything 'til you have changed the plugs. Quote Link to comment Share on other sites More sharing options...
parv Posted August 12, 2011 Report Share Posted August 12, 2011 What's the best way that I can check that?This is the first time that I've had to tinker with a 'modern' engine, I'm used to messing around with aircooled flat fours!!you just have to get the injector rail out and get and empty tub.,... get someone to turn the engine on and watch the injectors spraying.... its not risky.. but just be careful doing it.... Quote Link to comment Share on other sites More sharing options...
parv Posted August 12, 2011 Report Share Posted August 12, 2011 you just have to get the injector rail out and get and empty tub.,... get someone to turn the engine on and watch the injectors spraying.... its not risky.. but just be careful doing it....put it this way.. you have spark on that cylinder you say, so you might aswell check for fuel and eliminate small problems... Quote Link to comment Share on other sites More sharing options...
mccrindle Posted August 12, 2011 Author Report Share Posted August 12, 2011 waiting for spark plugs to be in stock hopefully get them tomorrow. but i switched car on quickly to see how it was running and it had a real pungent smell of petrol :/ Quote Link to comment Share on other sites More sharing options...
Defcon5 Posted August 12, 2011 Report Share Posted August 12, 2011 waiting for spark plugs to be in stock hopefully get them tomorrow. but i switched car on quickly to see how it was running and it had a real pungent smell of petrol :/possibly because the spark plug isnt working at all so the fuel that goes into the cylinder is going straight through without igniting Quote Link to comment Share on other sites More sharing options...
parv Posted August 13, 2011 Report Share Posted August 13, 2011 if its got a pungent smell of fuel then you must have no problem with fueling.... (most likely) but how sure are you about the spark on piston 4? Quote Link to comment Share on other sites More sharing options...
mccrindle Posted August 15, 2011 Author Report Share Posted August 15, 2011 replaced the spark plugs these were ok but did need replacing, problem is ht lead on cylinder 4 after checking everything. so going to replace all the ht leads Quote Link to comment Share on other sites More sharing options...
Defcon5 Posted August 15, 2011 Report Share Posted August 15, 2011 Glad you have got it sorted Quote Link to comment Share on other sites More sharing options...
mccrindle Posted August 16, 2011 Author Report Share Posted August 16, 2011 cheers for help people Quote Link to comment Share on other sites More sharing options...
