chrisash32 Posted January 25, 2011 Report Share Posted January 25, 2011 Hi Everyone,I have an issue where my new seats are not heating up very much at all....I have just bought some MK4 Recaros that all have brand new heated seat elements (Got receipt to prove it).My Lupo already had factory fit heated seats so i just disconnected the controllers from the bottom of the lupo seats and fitted these onto the MK4's.I can hear the relay kick in when i power the seats on, however they just don't seem to get very warm at all...Maybe just the equivalent of being on number 1 all the time..Anyone got any ideas?Many ThanksChris Quote Link to comment Share on other sites More sharing options...
Revo Posted January 26, 2011 Report Share Posted January 26, 2011 No idea how to fix the problem, but I am so jealous you have heated seats! Quote Link to comment Share on other sites More sharing options...
chrisash32 Posted January 27, 2011 Author Report Share Posted January 27, 2011 lolok, just to update, I have tried the seats with a temporary wire up ok a MK4 loom and switches, just to verify the pads are ok.The pads works fine, the seats got lovely and toasty.. However it still doesn't work when connected to the Lupo Loom....Still no idea why :s Quote Link to comment Share on other sites More sharing options...
Tricky88 Posted January 27, 2011 Report Share Posted January 27, 2011 Sorry - again no help but I feel your pain I tried for days to get my heated seats working with no luck. (mine was retro fitted standard Lupo gti heated leather).Good luck mate,Patrick Quote Link to comment Share on other sites More sharing options...
chrisash32 Posted January 27, 2011 Author Report Share Posted January 27, 2011 i should imagine Lupo GTi leather would work straight off with the OEM loom... (Which my Lupo has) my worry is that i am going to have to strip out the OEM Loom and fit a MK4 Loom and switches. I was sure someone had done it with the OEM Gear on here. :s Quote Link to comment Share on other sites More sharing options...
Mike_M Posted January 28, 2011 Report Share Posted January 28, 2011 You just need to make sure the wires are connected to the right ones on the switch, otherwise you will cause more damage than good................checked the fuses? Quote Link to comment Share on other sites More sharing options...
chrisash32 Posted January 28, 2011 Author Report Share Posted January 28, 2011 You just need to make sure the wires are connected to the right ones on the switch, otherwise you will cause more damage than good................checked the fuses?yeh fuses are fine.I have just printed off the circuit diagram for both systems. Going to take a look at where the differences are. Quote Link to comment Share on other sites More sharing options...
Tricky88 Posted January 28, 2011 Report Share Posted January 28, 2011 Didn't have an original loom as mine didn't have heated leather as standard, bought the kufatec one from Germany and sharan switches. Auto electrician pal said looks like elements are nakered unless anyone knows if the sharan switches aren't exactly the same as Lupo ones???Patrick Quote Link to comment Share on other sites More sharing options...
chrisash32 Posted October 11, 2011 Author Report Share Posted October 11, 2011 well i gave up on this as i didnt get anywhere and have not needed heated seats for the summer months.However the cold mornings are starting to close in and I want to have another shot at getting them wired up..Without fitting the MK4 loom and switches into the lupo, can anyone else think how i can get this to work correct with my OEM lupo loom and switches?Thanks!Chris Quote Link to comment Share on other sites More sharing options...
Mike_M Posted October 12, 2011 Report Share Posted October 12, 2011 Compare the wires from the lupo switch to the Golf one, and swap the wires that do not match.......obviously use a multimeter to check the connections match............otherwise take to an auto electrician to sort if not happy. Quote Link to comment Share on other sites More sharing options...
