Problems with my sub :(
Pete91
This will be down to the remote cable not working properly.
The remote ensures when the ignition turns off the amp (and or) sub turns off also and does not rinse the battery.
Check everything & if it still doesn't work come back, I have a few more ideas what it could possibly be :)
  • 6 months later...
Hey, sorry for the rediculously late reply!!
Problem finally solved, the issue was that the jvc head unit that i had recommended the power connections be switched to match the vw resulting in the remote power being on constantly. It seems to be quite a common thing when trying to connect to volkswagen's wiring harnesses. Cheers for all your help!!!!!
