Pete91 Posted November 30, 2010 Report Share Posted November 30, 2010 Hey,Basically i've hooked up my sub but it constantly drains my battery. I've connected it to the battery and to the remote power but it still drains my battery. Anyone had problems like this before?? Any advice is welcome!! Quote Link to comment Share on other sites More sharing options...
Henaz Posted November 30, 2010 Report Share Posted November 30, 2010 Double check that you have wired your amp to the ignition live to your headunit, normally a yellow wire, thats all it can really be Quote Link to comment Share on other sites More sharing options...
JoeA Posted November 30, 2010 Report Share Posted November 30, 2010 i dont know much, but if your stereo is wired up to be powered even when ignition is off then i think your sub will be on Quote Link to comment Share on other sites More sharing options...
Ben™ Posted November 30, 2010 Report Share Posted November 30, 2010 This will be down to the remote cable not working properly.The remote ensures when the ignition turns off the amp (and or) sub turns off also and does not rinse the battery.Check everything & if it still doesn't work come back, I have a few more ideas what it could possibly be Quote Link to comment Share on other sites More sharing options...
Pete91 Posted June 22, 2011 Author Report Share Posted June 22, 2011 Hey, sorry for the rediculously late reply!!Problem finally solved, the issue was that the jvc head unit that i had recommended the power connections be switched to match the vw resulting in the remote power being on constantly. It seems to be quite a common thing when trying to connect to volkswagen's wiring harnesses. Cheers for all your help!!!!! Quote Link to comment Share on other sites More sharing options...
