Mafyou Posted November 7, 2010 Report Share Posted November 7, 2010 Hi there, needing a bit of help here.I got spark plugs only two months ago (NKG Platnum). And the other day it started misfiring and the spark plugs were covered in oil. I have already cleaned the carb a couple and used a full tin of the stuff! I also put o breather filter on to try stop the oil getting in a couple months ago but the spark plugs still got oil on them. Any help or suggestions would be much appreciated, cheers. Quote Link to comment Share on other sites More sharing options...
Defcon5 Posted November 7, 2010 Report Share Posted November 7, 2010 Sorry, do you mean the spark plugs are getting oil on them from the crankcase breather? Quote Link to comment Share on other sites More sharing options...
Mafyou Posted November 7, 2010 Author Report Share Posted November 7, 2010 I mean the spark plugs getting oil on them. Quote Link to comment Share on other sites More sharing options...
Defcon5 Posted November 7, 2010 Report Share Posted November 7, 2010 Yes, I realise that but on the spark side or the HT side? The plugs are nowhere near the TB or PCV system, so unsure why you are mentioning them Quote Link to comment Share on other sites More sharing options...
Mafyou Posted November 7, 2010 Author Report Share Posted November 7, 2010 Oil is on the spark side Quote Link to comment Share on other sites More sharing options...
Mafyou Posted November 7, 2010 Author Report Share Posted November 7, 2010 Sorry forgot to mention, my cousin put the breather on and I'm not sure where it is but he said the oil won't get to the spark plugs. If what I said makes any sense at all lol Quote Link to comment Share on other sites More sharing options...
Defcon5 Posted November 7, 2010 Report Share Posted November 7, 2010 Possibly valve stem seals or piston rings, both are not uncommon unfortunatley. Quote Link to comment Share on other sites More sharing options...
Mafyou Posted November 7, 2010 Author Report Share Posted November 7, 2010 Don't know much about them lol, what shouldd I do? Quote Link to comment Share on other sites More sharing options...
Defcon5 Posted November 7, 2010 Report Share Posted November 7, 2010 Get your cheque book out I would get a professional diagnosis tbh, that way you will know for sure. If its not affecting the running of the car then it isnt too much of a problem. Are your emissions readings ok on the MOT? Quote Link to comment Share on other sites More sharing options...
Mafyou Posted November 7, 2010 Author Report Share Posted November 7, 2010 Yeah, well I went for one in March and they never mentioned anything so I'm assuming the emmisions are fine Quote Link to comment Share on other sites More sharing options...
VW_LUPO 1 Posted November 7, 2010 Report Share Posted November 7, 2010 Just take them out, clean them and replace them if it comes back then go see a professional. worn piston rings, but i have had oil on mine and i cleaned them and its fine. have you got blue smoke coming out the back, are you misfiring Quote Link to comment Share on other sites More sharing options...
Mafyou Posted November 8, 2010 Author Report Share Posted November 8, 2010 i took them out and cleaned them before and its came back but the spark plugs were pretty bad. this is the third time it has started misfiring. thereis no blue smoke, just runs stuttery and has low power when driving. tthank for the help btw Quote Link to comment Share on other sites More sharing options...
VW_LUPO 1 Posted November 8, 2010 Report Share Posted November 8, 2010 Have you put too much oil in your car whats the level like Quote Link to comment Share on other sites More sharing options...
Gti paul Posted November 8, 2010 Report Share Posted November 8, 2010 Have you checked the rocker cover gasket as on the z20let (Astra turbo) there common for this. Might be worth checking Buddy, Quote Link to comment Share on other sites More sharing options...
Mafyou Posted November 8, 2010 Author Report Share Posted November 8, 2010 oil level is ok. rocker cover gasket seems ok but Idon't know what I'm doing lol Quote Link to comment Share on other sites More sharing options...
VW_LUPO 1 Posted November 8, 2010 Report Share Posted November 8, 2010 Go to a garage before it gets worse! Quote Link to comment Share on other sites More sharing options...
Defcon5 Posted November 8, 2010 Report Share Posted November 8, 2010 Go to a garage before it gets worse!what are they going to do? It will be a massive job Quote Link to comment Share on other sites More sharing options...
VW_LUPO 1 Posted November 8, 2010 Report Share Posted November 8, 2010 what are they going to do? It will be a massive jobGarages are there for a reason. They fix your car Quote Link to comment Share on other sites More sharing options...
Defcon5 Posted November 8, 2010 Report Share Posted November 8, 2010 (edited) OP - is the car using a lot of oil? Edited November 19, 2010 by Defcon5 Quote Link to comment Share on other sites More sharing options...
Mafyou Posted November 8, 2010 Author Report Share Posted November 8, 2010 Yeah a bit more than usual. Il get it booked into VW and get a proper diagnosis Quote Link to comment Share on other sites More sharing options...
VW_LUPO 1 Posted November 9, 2010 Report Share Posted November 9, 2010 That sounds like a good plan I think Quote Link to comment Share on other sites More sharing options...
Mafyou Posted November 19, 2010 Author Report Share Posted November 19, 2010 It's either the rings or stem. The mechanic said best thin to do is get a new engine!!!!!!!!!!! Quote Link to comment Share on other sites More sharing options...
Mafyou Posted November 19, 2010 Author Report Share Posted November 19, 2010 Maybe goin to get 1.4 instead of a 1.0 anyone know what else i would need to do except from tell insurance. Quote Link to comment Share on other sites More sharing options...
VW_LUPO 1 Posted November 19, 2010 Report Share Posted November 19, 2010 flog the car then buy a new one Quote Link to comment Share on other sites More sharing options...
Defcon5 Posted November 19, 2010 Report Share Posted November 19, 2010 flog the car then buy a new oneSeems like it will be the easiest way out tbh, depends on the moral standing of the OP I guess! Quote Link to comment Share on other sites More sharing options...
