bobcr Posted September 23, 2010 Report Share Posted September 23, 2010 HiI wonder if anyone knows whether you can split the EGR valve on a 1.0 Lupo 2002 I got a fault code for the EGR valve and took the valve off to clean it, took the two screws out that look like they held the valve body to the alloy cast base but it wouldnt come apart, tried to split it with a blade bit no joy so just cleaned it as best I could and refitted it but now its leaking water out of the split where I tried to part it so must have damaged the seal. I will have to take it back off again ( a right pain of a job ! ) and either split it and fix the gasket or replace it.Any advice would be much appreciated.Bob Quote Link to comment Share on other sites More sharing options...
kermit Posted September 24, 2010 Report Share Posted September 24, 2010 HiI wonder if anyone knows whether you can split the EGR valve on a 1.0 Lupo 2002 I got a fault code for the EGR valve and took the valve off to clean it, took the two screws out that look like they held the valve body to the alloy cast base but it wouldnt come apart, tried to split it with a blade bit no joy so just cleaned it as best I could and refitted it but now its leaking water out of the split where I tried to part it so must have damaged the seal. I will have to take it back off again ( a right pain of a job ! ) and either split it and fix the gasket or replace it.Any advice would be much appreciated.BobI ended up replacing mine for £138 and 67p for the gasket. I tried what you have attempted with very little success sadly. Quote Link to comment Share on other sites More sharing options...
Defcon5 Posted September 25, 2010 Report Share Posted September 25, 2010 Can you block it without causing the ECU to spit its dummy out? Quote Link to comment Share on other sites More sharing options...
Bloomers Posted September 25, 2010 Report Share Posted September 25, 2010 No. If you block off the EGR the ECU brings up the 'Check' light on the display.I don't think it actually effects anything. From research people have said there is a chance of a performance gain. Although on a 1.0l I doubt it will be much, if any.Bloomers Quote Link to comment Share on other sites More sharing options...
bobcr Posted September 25, 2010 Author Report Share Posted September 25, 2010 I took it off and had another go at it but wouldnt split so made a blocking gasket out of copper sheet and put it back so I can use the car while I get a new one. Engine check light came on again but no difference in driving or power noticed. 1 Quote Link to comment Share on other sites More sharing options...
Todj Posted October 12, 2010 Report Share Posted October 12, 2010 I took it off and had another go at it but wouldnt split so made a blocking gasket out of copper sheet and put it back so I can use the car while I get a new one. Engine check light came on again but no difference in driving or power noticed.Got a similar issue with my 1.0 litre. Engine light on, VAGCOM gives an EGR fault code - but the car drives absolutely fine.Guess I'd best start by taking off the EGR and giving it a clean out. Question - can the valve be removed without shifting the airbox - or is it an Airbox Off job?Any thoughts on who's doing the best price on a new one (just in case the clean up doesn't work). Part number is 030 131 503 F.Thanks,Rich Quote Link to comment Share on other sites More sharing options...
Brammo Posted October 20, 2010 Report Share Posted October 20, 2010 I need to clean mine aswell. I think to get the whole system off you have to get the TB off aswell. Bit of a nightmare job really. Quote Link to comment Share on other sites More sharing options...
