joed05 Posted June 25, 2010 Report Share Posted June 25, 2010 i was out earlier with mates, there wasnt any really fast driving but when i went to start the engine up from hot again, there was a really high pitched whining noise, louder as throttle was applied. would this be the cambelt and need to be changed? would it be ok to drive in the meantime although its really loud, sort of like a supercharger.Thanks in advance Quote Link to comment Share on other sites More sharing options...
BaileyVW Posted June 25, 2010 Report Share Posted June 25, 2010 (edited) When i had this problem in my yellow lupo, someone told me it could be something to do with the waterpump? never noticed it when i was driving it myself from inside the car, however from outside it did sound similar to a charger. Edited June 25, 2010 by BaileyVW Quote Link to comment Share on other sites More sharing options...
joed05 Posted July 1, 2010 Author Report Share Posted July 1, 2010 Found the cause, a tensioners had shattered and rubbing against the cambelt, all fixed now and timing done but still won't start. Engine is turning over fine but just won't start, any ideas? Quote Link to comment Share on other sites More sharing options...
Pete Posted July 1, 2010 Report Share Posted July 1, 2010 You sure your timing is spot on? Being a tooth or two out can cause it to crank over but not fire up, not pulled out any sensors whilst doing the job? Quote Link to comment Share on other sites More sharing options...
jonnykell1980 Posted July 3, 2010 Report Share Posted July 3, 2010 Found the cause, a tensioners had shattered and rubbing against the cambelt, all fixed now and timing done but still won't start. Engine is turning over fine but just won't start, any ideas?its shattered? take it was still running before stripping? other than that i agree with loopete timings out or have you left something like the cam or crank sensor disconnected? Quote Link to comment Share on other sites More sharing options...
