LUKEY BOI Posted May 18, 2010 Report Share Posted May 18, 2010 Has any1 had overheating issues with their lupo i know its not headgasket its not leaking water and their is no gunk under oil cap or dipstick.Also the fan doesnt cut in but it does work as i bridged the connections also the thermostat has been changed.Could it be sender for the fan ? Or rad blocked ie the rads not getting hot enough to tell the fan to kick in.Any ideas please thanks Quote Link to comment Share on other sites More sharing options...
dd23 Posted May 18, 2010 Report Share Posted May 18, 2010 Has any1 had overheating issues with their lupo i know its not headgasket its not leaking water and their is no gunk under oil cap or dipstick.Also the fan doesnt cut in but it does work as i bridged the connections also the thermostat has been changed.Could it be sender for the fan ? Or rad blocked ie the rads not getting hot enough to tell the fan to kick in.Any ideas please thankstemp sender probs! Quote Link to comment Share on other sites More sharing options...
LUKEY BOI Posted May 18, 2010 Author Report Share Posted May 18, 2010 I was also thinking water pump maybe ill try sender but i dont wanna rip it apart if its not water pump Quote Link to comment Share on other sites More sharing options...
dd23 Posted May 18, 2010 Report Share Posted May 18, 2010 if waterpumps tend to fail,they either become noisy or collapse altogether(which would be very bad!!!) wack a tempsender in first (about 25 quid vag,or cheaper non gen)rule that out,then remove both hoses and stick a running hose pipe into the top hose you will then see if the rad is blocked by the flow out of the bottom of the rad.if you have had the thermostat replaced and the fan works when tested and have replaced the temp sender you may be looking at head gasket failure causing an airlock and not getting hot enuf to kick the fan in,this however is a worst case senario!!!hope this helps! Quote Link to comment Share on other sites More sharing options...
LUKEY BOI Posted May 18, 2010 Author Report Share Posted May 18, 2010 My mates gonna do a sniff test on it tomorrow and find out if theirs any exhaust gases in the water hope not Quote Link to comment Share on other sites More sharing options...
Defcon5 Posted May 19, 2010 Report Share Posted May 19, 2010 Another vote for temp sensor Quote Link to comment Share on other sites More sharing options...
LUKEY BOI Posted May 19, 2010 Author Report Share Posted May 19, 2010 Not headgasket as just found out where is tmp sender on the lupo ? is the sensore just before thermostat or another sensor ?? Quote Link to comment Share on other sites More sharing options...
Defcon5 Posted May 19, 2010 Report Share Posted May 19, 2010 yeah just before the stat. Its about ÂŁ25 from the stealers 1 Quote Link to comment Share on other sites More sharing options...
LUKEY BOI Posted May 20, 2010 Author Report Share Posted May 20, 2010 Been diagnosed as blocked radiator or failing water pump will flush rad see if its better and what comes out of it. Quote Link to comment Share on other sites More sharing options...
Defcon5 Posted May 20, 2010 Report Share Posted May 20, 2010 Does the rad not get hot then? Quote Link to comment Share on other sites More sharing options...
Tigz™ Posted May 20, 2010 Report Share Posted May 20, 2010 You wont get coolant in the oil if its head gasket, oil pressure is greater than water pressure so if anything, you'd get oil in the coolant.If you remove the top radiator pipe and have a feel to see if there's any gunk inside. Quote Link to comment Share on other sites More sharing options...
99hjhm Posted May 22, 2010 Report Share Posted May 22, 2010 (edited) You don't need oil in the water or the other way around for a blown headgasket. Could have gone between the cylinders and the coolant passages. Water pumps are ****e, impellors are plastic and are very very brittle, could have easilly broken up. If the rad is not getting hot, check thermostat then water pump. Edited May 22, 2010 by 99hjhm Quote Link to comment Share on other sites More sharing options...
nfbr Posted May 22, 2010 Report Share Posted May 22, 2010 A temp sensor will not cause a car to over heat... That's the stupidest thing I've ever heard!The waterpumps don't make any sound at all when they fail... They are more common to fail than the thermostats are, but if you're gonna be having the pump done, you may as well get another thermostat and brand new coolant at the same time! Quote Link to comment Share on other sites More sharing options...
Defcon5 Posted May 22, 2010 Report Share Posted May 22, 2010 A temp sensor will not cause a car to over heat... That's the stupidest thing I've ever heard!No but it could cause the temp guage to display the wrong temp, leading to the op thinking the car is overheating. Quote Link to comment Share on other sites More sharing options...
nfbr Posted May 22, 2010 Report Share Posted May 22, 2010 99% of the time, a knackered temp sensor will cause the temp gauge to read lower than it actually is.The other 1% it just wouldn't read anything at all on the temp gauge. Quote Link to comment Share on other sites More sharing options...
Defcon5 Posted May 22, 2010 Report Share Posted May 22, 2010 And 86% of statistics are made up on the spot Quote Link to comment Share on other sites More sharing options...
nfbr Posted May 22, 2010 Report Share Posted May 22, 2010 And 86% of statistics are made up on the spot I have the experience and knowledge to give those statistics... Unlike half the stupid 'Guesswork' that goes on around this forum. Quote Link to comment Share on other sites More sharing options...
