al3x kay Posted March 8, 2010 Report Share Posted March 8, 2010 Good Morning everyone,At the weekend I went to top up my oil, I noticed that there was a white/creamy substance on the inside of the oil cap, so I also look in the coolant and it had dropped, but only a little bit. So I am guessin that this means the Head Gasket is on its way out.The question I have is, how easy is this to do myself? I am reasonably good with a spanner. Where should I get the parts from? I need to get it done quickly as I don't have access to another car at the moment. Also, is there anything else that this could be? Am I jumping the gun?Any help would be much appreciated!p.s. Its a GTi (I'm not sure if that makes a difference). Quote Link to comment Share on other sites More sharing options...
Mike_M Posted March 8, 2010 Report Share Posted March 8, 2010 If the head gasket has gone it will require a cambelt change procedure for access due to the cam cover actually being a cam carrier.Do you do a lot of short journeys? Quote Link to comment Share on other sites More sharing options...
Defcon5 Posted March 8, 2010 Report Share Posted March 8, 2010 Its probably just the weather- leave it for a bit and keep an eye on the coolant. If you get mayo on the dipstick, then start to worry Quote Link to comment Share on other sites More sharing options...
al3x kay Posted March 8, 2010 Author Report Share Posted March 8, 2010 Its probably just the weather- leave it for a bit and keep an eye on the coolant. If you get mayo on the dipstick, then start to worryReally?I do an 8 mile trip to work, the engine always gets up to temperature.So you think I should just keep an eye on it then? Is there anything else that I should look out for? Thanks for the quick responses! Quote Link to comment Share on other sites More sharing options...
Defcon5 Posted March 8, 2010 Report Share Posted March 8, 2010 8 miles is nothing, the water may be up to temp but you need long journeys to aviod it the mayo. Its fine - just keep an eye on the coolant for piece of mind Quote Link to comment Share on other sites More sharing options...
