p88bel Posted November 18, 2004 Report Share Posted November 18, 2004 anyone got a diagram fior wiring that goes into the the lights switch things???Ive it all stripped out colour coding dash but have a boost guage need to illuminate so need to know where to tap it in so comes on with normal dash lightscheers guys Quote Link to comment Share on other sites More sharing options...
Tigz™ Posted November 18, 2004 Report Share Posted November 18, 2004 I havn't a diagram, nor have I looked but I would imagen if you connected directly to the switch, (there should be 2 wires in, and 2 wires out) then take it to a spare slot in the fuse bourd, then up to your boost gauge.Hopefully Snoop will come accross the diagram though in the mean time.Make sure you fuse it though mate, other wise you could damage both your switch and the gauge.:Edit: Think about it there may be 2 wires in and 3 out.The dash lights are connected to possision 2 on the switch anyway, Id imagen there'd be an out for the sidelamps, and 1 for the dash lights, then another out for the headlamps. Quote Link to comment Share on other sites More sharing options...
p88bel Posted November 18, 2004 Author Report Share Posted November 18, 2004 Ive got about 10 wires, mines had foggies and crap Quote Link to comment Share on other sites More sharing options...
Tigz™ Posted November 18, 2004 Report Share Posted November 18, 2004 Sorry didnt explain that very well.2 sets of wires in and 3 sets out. Quote Link to comment Share on other sites More sharing options...
Snoopy Posted November 18, 2004 Report Share Posted November 18, 2004 You can find the VW wiring diagrams for the light switch in this thread - click 'Wiring'.Any chance you could make your avatar smaller? Kinda breaks up the flow of the thread... Quote Link to comment Share on other sites More sharing options...
M1 Lupo Posted November 19, 2004 Report Share Posted November 19, 2004 How about finding the orange wire that goes to the ISO connectors on the stereo? The one that tells the stereo to illuminate its fascia.Use that to switch a relay for the gauge lighting. Quote Link to comment Share on other sites More sharing options...
Snoopy Posted November 19, 2004 Report Share Posted November 19, 2004 That wire's dimmed - if the gauge uses a `EL-type` backlight, it may not work correctly (i.e. you dim the dashboard and the gauge light goes from `full-on` to `full-off`).Not a major issue, but worth checking. Quote Link to comment Share on other sites More sharing options...
M1 Lupo Posted November 19, 2004 Report Share Posted November 19, 2004 Like I said, use it to switch a relay. That way its only using minimal power to energise the coil of the relay and the dial lighting is going to be fed with power from elsewhere. Thats the way I illuminated my Vacuum guage. Quote Link to comment Share on other sites More sharing options...
