Mike_M Posted October 9, 2009 Report Share Posted October 9, 2009 Well I am going to change the final fluid left to do in my GTI and this is the power steering.Any info or tips would be much appreciated, before I get stuck in Cheers in advance. Quote Link to comment Share on other sites More sharing options...
mat.m. Posted October 12, 2009 Report Share Posted October 12, 2009 Pull the lowest pipe off and let it drain out, refit the pipe. Measure how much fluid came out, then refill. Start it up and turn the wheel from left to right but not to the lock stops, top up if needed. Quote Link to comment Share on other sites More sharing options...
99hjhm Posted October 12, 2009 Report Share Posted October 12, 2009 Where did you get the fluid? It took ages to find some for mums Golf.... Without trying the dealers.Stupid question, as you probably went to the dealers? mat.m's advise seems good.Edit: just checked ELSA, 0.7 - 0.9l of fluid in system Quote Link to comment Share on other sites More sharing options...
Mike_M Posted October 12, 2009 Author Report Share Posted October 12, 2009 Cheers all.Will get the fluid from VW TPS Quote Link to comment Share on other sites More sharing options...
