STi Posted October 5, 2009 Report Share Posted October 5, 2009 Hello.I am wondering if anyone can help me find the reverse lamps fuse.My reverse lights are not working, I have checked the bulbs they are OK, I have changed the switch, still nothing, then I checked to see if there was power at the switch harness and there was not.So I thought it must be the fuse but love me, love me I`m thick, I cannot work out which one it is !?!Any help would be appreciated.Cheers.Sie. Quote Link to comment Share on other sites More sharing options...
jeyesh Posted October 5, 2009 Report Share Posted October 5, 2009 (edited) As a rough guess, number 25.I am not sure they have a fuse.As far as i know though, there is a switch on the gearbox that sets off the lights.Sorry I can't be of much help!Edit: Can't be 25, as you have no fuse there? Edited October 5, 2009 by jeyesh Quote Link to comment Share on other sites More sharing options...
northwick Posted October 5, 2009 Report Share Posted October 5, 2009 The reverse light sensor will have gone. Relatively common problem. Quote Link to comment Share on other sites More sharing options...
STi Posted October 6, 2009 Author Report Share Posted October 6, 2009 Many thanks for the replies but I have changed the already changed the switch.The problem is that I have no power getting to the switch.Sie. Quote Link to comment Share on other sites More sharing options...
Mike_M Posted October 6, 2009 Report Share Posted October 6, 2009 I had this problem on my Mk4 Golf where the wire had broken down inside the cable, causing the reverse lights to flicker before stopping all together.I had to test the two wires to find the faulty one and luckily only had to shorten it about an inch or so and re-solder to the switch plug before all was fine again. Quote Link to comment Share on other sites More sharing options...
