hartge Posted September 10, 2009 Report Share Posted September 10, 2009 (edited) Hi guys,my car (mk1 Arosa 1.4 mpi) always starts 3rd or 4th time each morning from cold. Crank the engine then 2 secs later off, try again, same or just about gets the revs up and idles. (usually give it alittle throttle to get it going)I have had a full service on the car, changed HT leads, what else could it be or changed? Does anyone have a Vagcom around the Oxfordshire area that could check it out for me incase it has any errors?Really annoying every morning, when its warmed up properly it starts up first time!any ideas?Cheers Edited September 10, 2009 by hartge Quote Link to comment Share on other sites More sharing options...
NOCK Posted September 11, 2009 Report Share Posted September 11, 2009 Might sound stupid but how old is your battery? Quote Link to comment Share on other sites More sharing options...
hartge Posted September 11, 2009 Author Report Share Posted September 11, 2009 Might sound stupid but how old is your battery?Not sure mate, but will have it checked out, cheers Quote Link to comment Share on other sites More sharing options...
Mike_M Posted September 11, 2009 Report Share Posted September 11, 2009 Coil pack could be corroded which is a common issue...........changed mine last year with the HT leads and new plugs while it was all offSpark plugs also have to bedone every 2 years........when were yours done? Quote Link to comment Share on other sites More sharing options...
hartge Posted September 11, 2009 Author Report Share Posted September 11, 2009 Coil pack could be corroded which is a common issue...........changed mine last year with the HT leads and new plugs while it was all offSpark plugs also have to bedone every 2 years........when were yours done?I changed the HT leads yesterday and had a service with all gen VW parts around 3 weeks ago. Quote Link to comment Share on other sites More sharing options...
hartge Posted October 2, 2009 Author Report Share Posted October 2, 2009 just up update guys, I have changed the Coolant Temp sensor and it starts up 1st time everytime I still get a rough-ish idle now and again, im guessing something to do with the throttle body as it sometimes hesitates when accelerating. Quote Link to comment Share on other sites More sharing options...
JDarosa Posted October 8, 2009 Report Share Posted October 8, 2009 you may want to check the gap on the spark plugs as well mate cause they have been dropped at some point Quote Link to comment Share on other sites More sharing options...
