funkycooljem Posted August 17, 2009 Report Share Posted August 17, 2009 ok so im havin a bit of trouble with my 1.4 sport! i think the piston rings have gone, its drinking oil (was full then 3 weeks later was completely empty) also there is black stuff (poss oil lol) all up the back of my car! so is it worth gettin it fixed and if so aprox how much am i lookin at? or should i sell it and get another one? its in good nick, already had the pedal box done, but also got a small leak in the windscreen. Quote Link to comment Share on other sites More sharing options...
Niche Posted August 17, 2009 Report Share Posted August 17, 2009 (edited) Might be piston rings...what's the current mileage?Could also be you putting in rubbish oil...Quantum Synta Gold 5W-40 works well.Could just be compartment in the back box being full of oil.Your backbox is split into three sections, the first section stores oil that passes through the exhaust, this falls through the holes in the first section. It may well be that this compartment is now full...especially if you're losing as much oil as your stating.But even under normal consumption this compartment could be full already, juding from pictures I've seen. I always found myself topping up oil every month by about a quarter of the dipstick.Give it another oil change with the stuff I've recommended and put in some Forte engine cleaner. Procedure is to put in Forte cleaner, leave on tick over for 30 minutes, drain oil (very thin at this point), renew oil filter, renew sump plug and sump plug seal, top up with 3 litres, probably best to do just under and top up to the dipstick level. Then see how much it consumes. Edited August 17, 2009 by Niche Quote Link to comment Share on other sites More sharing options...
sheps Posted August 17, 2009 Report Share Posted August 17, 2009 Most probably piston rings i have just had the same problem with mine was putting around half a litre in every week, had the black deposits up the back of the car and milage was only 60k. ended up getting a full engine rebuild as i didn't want to let the car go. Now runs better than it ever has, If you do i'd reccomend the engine shop. Sam Quote Link to comment Share on other sites More sharing options...
funkycooljem Posted August 17, 2009 Author Report Share Posted August 17, 2009 cheers guys, think it prob is the piston rings! its only done 67k but hey never mind! any ideas on cost? Quote Link to comment Share on other sites More sharing options...
99hjhm Posted August 17, 2009 Report Share Posted August 17, 2009 (edited) It will probably be valve stem seals and piston rings..... Although changing the rings might not cure the issue for long, If you have bore wear.I would look for a low milage crashed lupo for the engine. Edited August 17, 2009 by 99hjhm Quote Link to comment Share on other sites More sharing options...
jamiea7x Posted August 17, 2009 Report Share Posted August 17, 2009 im getting the black deposits up the back of my car and using oil but at th emoment i can live with it the engine runs fine and well Quote Link to comment Share on other sites More sharing options...
jamiea7x Posted August 17, 2009 Report Share Posted August 17, 2009 im getting the black deposits up the back of my car and using oil but at th emoment i can live with it the engine runs fine and welloh and im only sitting at 41k Quote Link to comment Share on other sites More sharing options...
funkycooljem Posted August 18, 2009 Author Report Share Posted August 18, 2009 went to a stealership today for a bit of advice and he dont think its the piston rings but more likely to be the valve seals... dont really wanna buy a new engine coz knowin my luck it will do the same lol as it seems to be a pretty common problem lol, they guy at the stealership said sell it and buy a gti coz u dont get as many probs with those lol but i cant afford one Quote Link to comment Share on other sites More sharing options...
hunid-brake Posted August 20, 2009 Report Share Posted August 20, 2009 Oh dear. I was only telling a girl on here last week to get a gti not a sport because of problems if only she could of seen this. I had a sport and had every problem under the sun apart from this. God bless the gti. It will save you money and retain it's value in the long run. Quote Link to comment Share on other sites More sharing options...
Toon Posted August 20, 2009 Report Share Posted August 20, 2009 Are the deposits like black spots up the back of the car? Quote Link to comment Share on other sites More sharing options...
jamiea7x Posted August 20, 2009 Report Share Posted August 20, 2009 mine is loads of wee black specks yes, just looks like carbon deposits not sure if its related to an engine problem or not tho.. Quote Link to comment Share on other sites More sharing options...
funkycooljem Posted August 20, 2009 Author Report Share Posted August 20, 2009 yeah its kinda little black sooty spots, its where the oil is gettin into the combustion chamber then comin out of the exhaust. at first i didnt think it was oil coz it wasnt sticky at all but if ya stick a pair of gloves on and feel the deposits inside ya tail pipe its a bit tacky. Quote Link to comment Share on other sites More sharing options...
Niche Posted August 20, 2009 Report Share Posted August 20, 2009 Bah...my Sport was on 67k when I sold it and it never drank oil. Just the normal consumption that's expected for this sort of engine as I mentioned in my earlier post.Frequent oil changes and an engine oil cleaner could help. Quote Link to comment Share on other sites More sharing options...
sheps Posted August 20, 2009 Report Share Posted August 20, 2009 From speaking to a local vw specialist there are good and bad engines something to do with the quality of materials they use for the internal seals, rings etc. He seemed to think that some engine codes seemed to be more reliable than others. From speaking to other members on here also it seems that a few of the AFK models were not too good (like mine going at 64k) Whereas my friends has something like 80k and no sign of any problems (different code). But i've run in my engine fully and done a few miles since the rebuild and all seems to be good. In fact best its run in my ownership.... Though saying that mine was getting the black deposits on the back from when i got it though didnt think much of it to start with. So i guess the previous owner must have known. Knowing what the problem was i thought it was best i got it sorted and stick with the car rather than sell it on and pass on the problem. Hope this helps in some way, Sam. Quote Link to comment Share on other sites More sharing options...
Niche Posted August 20, 2009 Report Share Posted August 20, 2009 Yeah mine was AFK.It's probably down to people changing oil every 10k and not checking oil levels.I changed my oil every 5k with Synta Gold and checked the levels on a monthly basis and topped up as necessary with spare oil from the 5 litre container.Although as you say crap parts don't help regardless.My current 3 cylinder doesn't drink a drip of oil. Water comes out the exhaust. Quote Link to comment Share on other sites More sharing options...
sheps Posted August 20, 2009 Report Share Posted August 20, 2009 "My current 3 cylinder doesn't drink a drip of oil. Water comes out the exhaust." Don't those 3 cylinder engine run on water anyhow Quote Link to comment Share on other sites More sharing options...
jamiea7x Posted August 20, 2009 Report Share Posted August 20, 2009 hmmm i have the aub engine...nticed that oil is getting into the throttlee body throught the little pipe going into the airbox... Quote Link to comment Share on other sites More sharing options...
Niche Posted August 20, 2009 Report Share Posted August 20, 2009 (edited) hmmm i have the aub engine...nticed that oil is getting into the throttlee body throught the little pipe going into the airbox...That's your oil breather pipe and is perfectly normal. Make sure that pipe is never blocked. Some people put filters at the end of them to stop oil going through the throttle body but you end up smelling fumes in your car as a result.On the newer Polo's that pipe is attached to the inlet manifold preventing oil from entering the throttle body."My current 3 cylinder doesn't drink a drip of oil. Water comes out the exhaust." Don't those 3 cylinder engine run on water anyhow Nah, for some weird reason though you get a set of bike pedals to push instead of a gas pedal. Lupo's run on Synta Gold 5w-40.Polo 1.2 3 pot engines run on Synta LongLife III 5W-30 which costs bucks compared to Gold mate. Although I'm running it on Gold and it's running very well. Edited August 20, 2009 by Niche Quote Link to comment Share on other sites More sharing options...
