Pictures of doors
Good to hear it.
And I take it your not doing the silly thing and useing audio cable?
http://www.johndavies.co.uk/newweldingcabl...andfittings.htm
SW1009 £1.68 50mm² Max 320A Continuous
And no matter what anyone says, it is just as easy to work with as audio cable, I used 0awg as did LoudLupo, and neither of us had problems routing it.
Here you go. One door minus the lower card. Plus 2 rolls of Dynamat extreme!
Door.JPG border="0" class="linked-image" /> border="0" class="linked-image" />
You can even spot the VW parking only sign in the background...
I deadened the whole door skin from top to bottom, and there is a triple layer behind the speaker. Actually the whole car has at least a single layer.
I'm not too bothered by the weight really, 9 rolls of sound deadening is nothing when you have a sub which weighs 20kg without the box in the back...
The components are sounding full on beautifull! Mids trying to jump out of the doors / snap your legs with thier punch. Tweeters play with so much accuracy you can hear the sound of the plec on the strings and the singer breathing whilst singing. Pure bliss!
I think they need about 10 - 15 more hours of listening to loosen up a bit more. Plus redesign the box for the sub to have a larger port. Then im done till I can spend some ££££ on signal processing.
