LUKEY BOI Posted July 15, 2009 Report Share Posted July 15, 2009 Hi when replacing valve stem seals how many do i need to do the job.thanks Quote Link to comment Share on other sites More sharing options...
Defcon5 Posted July 15, 2009 Report Share Posted July 15, 2009 (edited) One for each valve? May as well do them allThought you were changing the engine? Edited July 15, 2009 by Defcon5 Quote Link to comment Share on other sites More sharing options...
LUKEY BOI Posted July 15, 2009 Author Report Share Posted July 15, 2009 so will need 16 of the buggers lol people got any tips when doing this job to make it easier ect or a guide cos me and my dad are gonna do it Quote Link to comment Share on other sites More sharing options...
cobblers Posted July 15, 2009 Report Share Posted July 15, 2009 You need 16 valve stem seals for an engine with 16 valves. Quote Link to comment Share on other sites More sharing options...
LUKEY BOI Posted July 15, 2009 Author Report Share Posted July 15, 2009 lol i never said i was changing the engine lol im new here dude lol just got a lupo thats immaculate for 800 cos of these seals that need doing and just needed few tips lol D Quote Link to comment Share on other sites More sharing options...
CasperGTI Posted July 15, 2009 Report Share Posted July 15, 2009 What engine?Give me the year and the engine code and ill get the workshop manual print out for it.John Quote Link to comment Share on other sites More sharing options...
LUKEY BOI Posted July 15, 2009 Author Report Share Posted July 15, 2009 (edited) What engine?Give me the year and the engine code and ill get the workshop manual print out for it.Johni dunno mate its a 1.4 e 75 bhp 1999 so whatever engine this is well gratefull for the help Edited July 15, 2009 by LUKEY BOI Quote Link to comment Share on other sites More sharing options...
Defcon5 Posted July 15, 2009 Report Share Posted July 15, 2009 lol i never said i was changing the engine lol im new here dude lol just got a lupo thats immaculate for 800 cos of these seals that need doing and just needed few tips lol DAhh sorry, someone else mentioned it in one of your other threads. Should be a good project to fix it up! Quote Link to comment Share on other sites More sharing options...
99hjhm Posted July 15, 2009 Report Share Posted July 15, 2009 As far as I know, you need to remove the head to do the stem seals??? Quote Link to comment Share on other sites More sharing options...
CasperGTI Posted July 15, 2009 Report Share Posted July 15, 2009 You can do them with the head on but you need special air powered compressor adaptor to keep the valve seated whilst you remove the spring.Easiest to take the head off.Ill find the workshop manual tomorrow. if you can get the engine code that would be helpful. Quote Link to comment Share on other sites More sharing options...
LUKEY BOI Posted July 15, 2009 Author Report Share Posted July 15, 2009 where is the engine code matey would i need special tools if i took the head off ? Quote Link to comment Share on other sites More sharing options...
pro3mark Posted July 15, 2009 Report Share Posted July 15, 2009 Should be on the sticker in the boot (under the carpet) Quote Link to comment Share on other sites More sharing options...
99hjhm Posted July 15, 2009 Report Share Posted July 15, 2009 (edited) where is the engine code matey would i need special tools if i took the head off ?nothing to special I don't think, not as bad as a GTI.You will need a head gasket set, and a set of head bolts??....Casperyou want to be doing the cam belt aswell, unless it's been done recently.Clean the breather box on the back of the block with the head off and the throttle body.John.... Do you have ELSA or something else?? Edited July 15, 2009 by 99hjhm Quote Link to comment Share on other sites More sharing options...
LUKEY BOI Posted July 15, 2009 Author Report Share Posted July 15, 2009 Should be on the sticker in the boot (under the carpet)okay will look their tomorrow Quote Link to comment Share on other sites More sharing options...
lupoluke Posted July 15, 2009 Report Share Posted July 15, 2009 I would also lap (regrind) the valve seats while your there. Quote Link to comment Share on other sites More sharing options...
LUKEY BOI Posted July 15, 2009 Author Report Share Posted July 15, 2009 I would also lap (regrind) the valve seats while your there.i sure would if i knew how lol Quote Link to comment Share on other sites More sharing options...
lupoluke Posted July 15, 2009 Report Share Posted July 15, 2009 You will need one of these (there will be alot of info on google how to use it) http://cgi.ebay.co.uk/Chemico-Valve-Grindi...%3A1%7C294%3A50And also one of these so you can compress the spring valves and remove the collets.http://cgi.ebay.co.uk/200mm-8-Valve-Spring...%3A1%7C294%3A50 Quote Link to comment Share on other sites More sharing options...
LUKEY BOI Posted July 15, 2009 Author Report Share Posted July 15, 2009 You will need one of these (there will be alot of info on google how to use it) http://cgi.ebay.co.uk/Chemico-Valve-Grindi...%3A1%7C294%3A50And also one of these so you can compress the spring valves and remove the collets.http://cgi.ebay.co.uk/200mm-8-Valve-Spring...%3A1%7C294%3A50is this the tool i need if i dont want to remove the head ???could someone post a guide on how to do this job considering it seems these seals are a common problem ??? Quote Link to comment Share on other sites More sharing options...
lupoluke Posted July 15, 2009 Report Share Posted July 15, 2009 I haven't had the head off a lupo, but the valve spring compresser is used when the head is off the engine to remove the valves, also get a torque wrench for the head bolts when you are putting it all back together. Quote Link to comment Share on other sites More sharing options...
99hjhm Posted July 15, 2009 Report Share Posted July 15, 2009 The tool(s) needed to do the seals on the car are very hard to get, and expensive..... it's also very hard to do.Whip the head off, strip it, change the seals... not that hard really.Go to halfords, get a manual for a 1998-200? Mkiv Golf and look at the 1.4L 16v engine section, it should give you all the info you need. Quote Link to comment Share on other sites More sharing options...
LUKEY BOI Posted July 15, 2009 Author Report Share Posted July 15, 2009 I haven't had the head off a lupo, but the valve spring compresser is used when the head is off the engine to remove the valves, also get a torque wrench for the head bolts when you are putting it all back together.okay mate cheers for all your help i appreciate it will upload pics of me doing it when i do Quote Link to comment Share on other sites More sharing options...
cobblers Posted July 16, 2009 Report Share Posted July 16, 2009 I've read of people making the tool to hold the valves up by lopping the guage off a compression tester and lashing what's left onto an airline (through a valve to regulate the air flow)I've got a head in my garage that needs the seals doing but is otherwise fine, so you can do them, then swap it on. Make me an offer (it's still built up as an engine) I don't want much! Quote Link to comment Share on other sites More sharing options...
CasperGTI Posted July 16, 2009 Report Share Posted July 16, 2009 (edited) nothing to special I don't think, not as bad as a GTI.You will need a head gasket set, and a set of head bolts??....Casperyou want to be doing the cam belt aswell, unless it's been done recently.Clean the breather box on the back of the block with the head off and the throttle body.John.... Do you have ELSA or something else??cobblers - thats the tool im talkng about, you need approx 6 bar of air pressure to hold the valve up in its seat whilst removing the valve spring.Id get a set of head bolts and a head gasket. Might aswell do the belt too if youve go spare money.You can pick up a belt kit for about £90, head gasket is about £20 and a set of head bolts i think is about £30. then the stem seals are about £2-£3 each.As james has said, its not a simple job, ideally you need to remove the head (which means taking the cam belt off, inlet mani off and exhaust mani off) You have to take the head bolts out in sequence otherwise you can warp the head (ive seen it happen). You do need a few "special" tools, unless you know a friend in a workshop where you can borrow them from id sudjest you think about doing it yourself first.You dont have to re lap in the valves, if it aint broke dont fix it. Just mark up every valve to each individual port and put them back where they came from and you should be alright. Only if you were changing valves or had compression problems would you need to lap the valves in.Have you or your old man done anything like this before? If so then you should be fine, if not id be a bit weary of doing it. James, i have both etka and elsa. Its quite handy at times. Edited July 16, 2009 by CasperGTI Quote Link to comment Share on other sites More sharing options...
scotty_82 Posted July 16, 2009 Report Share Posted July 16, 2009 (edited) I have a crystal ball , i can see this going so so wrongand the lotto for saturday are 7,15,23,27,34,38 Edited July 16, 2009 by scotty_82 Quote Link to comment Share on other sites More sharing options...
LUKEY BOI Posted July 16, 2009 Author Report Share Posted July 16, 2009 My dad does it for a job lol it just me who doesnt have a clue lol Quote Link to comment Share on other sites More sharing options...
