pietch Posted July 12, 2009 Report Share Posted July 12, 2009 Looking for a front TDI brake upgrade without loosing std. 14" wheels... I reamember reading about VW Corrado G60 calipers / discs may work?Can anyone confirm an nice inexpensive upgrade?Thanks all! ps. Are TDI brakes the same as GTI and or 1.4 / 1.0 versions? Quote Link to comment Share on other sites More sharing options...
nfbr Posted July 12, 2009 Report Share Posted July 12, 2009 Standard wheels didn't fit over the G60 carriers when I had mine. When I went back to the 7x14"s I had to go back to 256mm Discs. Quote Link to comment Share on other sites More sharing options...
pietch Posted July 12, 2009 Author Report Share Posted July 12, 2009 Thanks for the imput nfbr...So is there an upgrade solution other then performance discs and pads?Standard wheels didn't fit over the G60 carriers when I had mine. When I went back to the 7x14"s I had to go back to 256mm Discs. Quote Link to comment Share on other sites More sharing options...
nfbr Posted July 12, 2009 Report Share Posted July 12, 2009 Braded Hoses and better Brake Fluid may make a little difference.You'd get better results using good quality fast road discs and pads than you would upgrading to 280mm anyway.You could always get hold of some GTI Calipers and move upto 25mm Wide discs instead of the 20mm wide discs on the TDI. Quote Link to comment Share on other sites More sharing options...
northwick Posted July 12, 2009 Report Share Posted July 12, 2009 I have some G60 calipers (same size as GTI ones) for sale if you want to follow that route. Quote Link to comment Share on other sites More sharing options...
northwick Posted July 12, 2009 Report Share Posted July 12, 2009 You'd get better results using good quality fast road discs and pads than you would upgrading to 280mm anyway.In some respects, yes but its not that straight forward. The ABS is less prone to kicking in unnecessarily with the bigger discs, for example. Quote Link to comment Share on other sites More sharing options...
nfbr Posted July 12, 2009 Report Share Posted July 12, 2009 In some respects, yes but its not that straight forward. The ABS is less prone to kicking in unnecessarily with the bigger discs, for example.What is your source on this information? I'd like to read up a little more on it. Quote Link to comment Share on other sites More sharing options...
northwick Posted July 12, 2009 Report Share Posted July 12, 2009 The ABS? Its just from personal experience but I know that Mike M has had similar experiences too.The argument for the fast road discs and pads is the pad area is still the same whether or not its a 256mm or 280mm disc which is true. But for the same reasons that it would be easier to slow down a larger childrens roundabout spinning at the same speed as a smaller one when standing at its edge, the larger discs mean more control over the braking and the ABS kicks in less. Quote Link to comment Share on other sites More sharing options...
pietch Posted July 13, 2009 Author Report Share Posted July 13, 2009 Do the 5mm thicker GTi discs just bolt on or do I need the GTi calipers also?Thanks nfbr Quote Link to comment Share on other sites More sharing options...
nfbr Posted July 13, 2009 Report Share Posted July 13, 2009 The ABS? Its just from personal experience but I know that Mike M has had similar experiences too.The argument for the fast road discs and pads is the pad area is still the same whether or not its a 256mm or 280mm disc which is true. But for the same reasons that it would be easier to slow down a larger childrens roundabout spinning at the same speed as a smaller one when standing at its edge, the larger discs mean more control over the braking and the ABS kicks in less.Yeah, Kinda makes sence with the abs as the fulcrum will be longer making the braking more progressive and less lightly to lock up.Do the 5mm thicker GTi discs just bolt on or do I need the GTi calipers also?Thanks nfbrThe calipers would be needed too as they are a wider caliper to suit the wider disc. Quote Link to comment Share on other sites More sharing options...
pietch Posted July 13, 2009 Author Report Share Posted July 13, 2009 Thanks nfbr! Quote Link to comment Share on other sites More sharing options...
