Janebrink Posted January 29, 2009 Report Share Posted January 29, 2009 It's all the time. Sooooo annoying! Its like when the swaybar struts give up on an old volvo.(or is it called antirollbar links in english) A clicking noise. However, the Lupo does not have these so thats not the problem. Just mentioned it to describe the sound... Does anyone know if this is a known problem? Any bushings that wear out?Regards,Anders. Quote Link to comment Share on other sites More sharing options...
heartagram Posted January 30, 2009 Report Share Posted January 30, 2009 Possibly ****ed top mounts? Quote Link to comment Share on other sites More sharing options...
Mike_M Posted January 30, 2009 Report Share Posted January 30, 2009 That too me sounds like something is loose, either a bolt / nut or a worn bush allowing for play.It might be worth jacking up the rear end and checking everything and also rotating the springs (grab and turn about 90 degrees) Quote Link to comment Share on other sites More sharing options...
Janebrink Posted January 30, 2009 Author Report Share Posted January 30, 2009 Possibly ****ed top mounts? This is exactly what I suspected... Just wanted to know if it's a common thing on theese cars. I'll try to rotate my springs aswell. It might just be that easy. But on the other hand, I feel that the amounts of "clicks per second" is to high to be like a bushing or similar. The noise is more frequent than the cars suspension going up and down... But I'll check.Thanks. Quote Link to comment Share on other sites More sharing options...
Mike_M Posted January 30, 2009 Report Share Posted January 30, 2009 Checked the wheel bolts are tight! Quote Link to comment Share on other sites More sharing options...
