James_d89 Posted November 7, 2008 Report Share Posted November 7, 2008 Hey every1, i dont know if this is just a thing with the lupo Sports or anything, but at times the gears are Really hard to get in and out of certain ones, mainly going in and out of 3rd and 4th, and sometimes going into 2nd and 1st.Any help?James Quote Link to comment Share on other sites More sharing options...
LJ51NXX Posted November 7, 2008 Report Share Posted November 7, 2008 Is your clutch pedal lower than your brake pedal? Quote Link to comment Share on other sites More sharing options...
heartagram Posted November 7, 2008 Report Share Posted November 7, 2008 Mine did this. At first it wasn't to bad then it got worst and worst until it just started losing gears altogether. Ended up putting a new box on it. Quote Link to comment Share on other sites More sharing options...
matt~black Posted November 7, 2008 Report Share Posted November 7, 2008 should have bought a gti dude Quote Link to comment Share on other sites More sharing options...
James_d89 Posted November 7, 2008 Author Report Share Posted November 7, 2008 should have bought a gti dudewanted a GTi but the insurance was far to much! and im not surea bout the brake and clutch pedal hights, why would that make a differnace?James Quote Link to comment Share on other sites More sharing options...
bossjohnc Posted November 7, 2008 Report Share Posted November 7, 2008 Take a look around the forum, search for "Sport" and "Pedal Box", that will get you started.Essentially, there's a weak weld in the pedal boxes of Lupo Sports which means that they fail prematurely.VW have acknowledged this and if your pedal box is faulty, your car less than 7 years old and under 100,000 miles, you should be able to get it replaced gratis at a dealer - although you'll probably need to press the right buttons.Your symptoms are that of a failing pedal box.Clicky Quote Link to comment Share on other sites More sharing options...
James_d89 Posted November 7, 2008 Author Report Share Posted November 7, 2008 Is your clutch pedal lower than your brake pedal?Just checked and my clutch pedal is lower than my brake pedal. how does this affect it? and easy to cure?James Quote Link to comment Share on other sites More sharing options...
James_d89 Posted November 7, 2008 Author Report Share Posted November 7, 2008 Take a look around the forum, search for "Sport" and "Pedal Box", that will get you started.Essentially, there's a weak weld in the pedal boxes of Lupo Sports which means that they fail prematurely.VW have acknowledged this and if your pedal box is faulty, your car less than 7 years old and under 100,000 miles, you should be able to get it replaced gratis at a dealer - although you'll probably need to press the right buttons.Your symptoms are that of a failing pedal box.ClickyMy loop is 29,000 miles but is 2000/Wreg. so im guessing they wont change it for me?And how much would a new pedal box be to replace roughly?James Quote Link to comment Share on other sites More sharing options...
bossjohnc Posted November 8, 2008 Report Share Posted November 8, 2008 I think all the info is in that thread - it's a pig to change labour wise, but you might be able to get a handy welder to do it without taking the box out if VW won't pay. Quote Link to comment Share on other sites More sharing options...
heartagram Posted November 8, 2008 Report Share Posted November 8, 2008 I'm sure its around £350 if you pay for it out of your own pocket. Just get friendly with a dealership and they will help you out. Quote Link to comment Share on other sites More sharing options...
James_d89 Posted November 11, 2008 Author Report Share Posted November 11, 2008 Iv been to my local VW dealer with the problem, they said that with the recalling lupos and such they cant fix mine free of charge due to it being nearly 2 years out on their recal warrenty, however they will fix it at a reduced price of £220 instead of £380-400.Im considering buying the components from them, which were only £34 for the lot (which was 3 bits) and having a friend of mine who is a local mechanic put it all in for me. Hopfuly he will do it for me at a good price! He also thinks he will beable to help my supercharge the loop, so im hoping everything is going to go well!Will keep you all posted on any updates!James Quote Link to comment Share on other sites More sharing options...
