dj_lupz Posted June 17, 2008 Report Share Posted June 17, 2008 is there a way off re setting ur sunroof??i'm havin problems with mine not closin flush and also when its fully open and i want to close it, it starts to close the stops and goes back i have to force it to shut.i no these are very sensative so i have clean and checked that it isn't catching any where and nough has changedhas any 1 elles had this probelm?advise please Quote Link to comment Share on other sites More sharing options...
Niche Posted June 17, 2008 Report Share Posted June 17, 2008 (edited) is there a way off re setting ur sunroof??i'm havin problems with mine not closin flush and also when its fully open and i want to close it, it starts to close the stops and goes back i have to force it to shut.i no these are very sensative so i have clean and checked that it isn't catching any where and nough has changedhas any 1 elles had this probelm?advise pleaseSame thing happens with mine.To get the sunroof to close flushed pull down the panel around the dial and you should have a metal rod in your boot which allows you to manually adjust it, adjust it so that the sunroof is flushed when shut.To get the sunroof to shut fully when slid open without forcing it turn the dial a quarter shut so its half way closed. Then turn the dial bit-by-bit and it will shut without any issues.VW quoted me £1,000 to fit new rails and an electric motor. It would be nice if you could find a quote for about £800 less than that LOL. Edited June 17, 2008 by Niche Quote Link to comment Share on other sites More sharing options...
dj_lupz Posted June 17, 2008 Author Report Share Posted June 17, 2008 Same thing happens with mine.To get the sunroof to close flushed pull down the panel around the dial and you should have a metal rod in your boot which allows you to manually adjust it, adjust it so that the sunroof is flushed when shut.To get the sunroof to shut fully when slid open without forcing it turn the dial a quarter shut so its half way closed. Then turn the dial bit-by-bit and it will shut without any issues.VW quoted me £1,000 to fit new rails and an electric motor. It would be nice if you could find a quote for about £800 less than that LOL. Quote Link to comment Share on other sites More sharing options...
Mike_M Posted June 17, 2008 Report Share Posted June 17, 2008 If you take the trim panel off and insert the allen key supplied to manually wing the sunroof shut then try the sunroof with the switch it should be fine again Quote Link to comment Share on other sites More sharing options...
dj_lupz Posted June 17, 2008 Author Report Share Posted June 17, 2008 If you take the trim panel off and insert the allen key supplied to manually wing the sunroof shut then try the sunroof with the switch it should be fine againcheers mate i'll have a pop at tht Quote Link to comment Share on other sites More sharing options...
Mike_M Posted June 17, 2008 Report Share Posted June 17, 2008 The allen key tool is attached to the sunroof switch trim panel.......when you remove it you will see. Quote Link to comment Share on other sites More sharing options...
dj_lupz Posted June 18, 2008 Author Report Share Posted June 18, 2008 (edited) If you take the trim panel off and insert the allen key supplied to manually wing the sunroof shut then try the sunroof with the switch it should be fine againu are a legend cheers matesun roof is sitin flush now Edited June 18, 2008 by dj_lupz Quote Link to comment Share on other sites More sharing options...
Mike_M Posted June 18, 2008 Report Share Posted June 18, 2008 No problem Quote Link to comment Share on other sites More sharing options...
myRie Posted November 8, 2011 Report Share Posted November 8, 2011 Im still stuck with this... I pull the sunroof dial off and left with a blue dial, do i need to remove this dial also? Quote Link to comment Share on other sites More sharing options...
