Lupo Loopy Posted January 24, 2008 Report Share Posted January 24, 2008 Hello,My doors are a little wayward, but look like they just need squeezing in a bit by moving the keepers. It sounds like the window is down a bit when driving at speed becasue of the lack of pressure on the seal. Does anyone know what tool I need to move them? It looks like a Torx 9 million or something?Does anyone have any tips on door tweaks. My doors creak and crack when opened and closed and feel notchy as you pull them shut.CheersLL Quote Link to comment Share on other sites More sharing options...
mcbeal_88 Posted January 25, 2008 Report Share Posted January 25, 2008 Hello,My doors are a little wayward, but look like they just need squeezing in a bit by moving the keepers. It sounds like the window is down a bit when driving at speed becasue of the lack of pressure on the seal. Does anyone know what tool I need to move them? It looks like a Torx 9 million or something?Does anyone have any tips on door tweaks. My doors creak and crack when opened and closed and feel notchy as you pull them shut.CheersLLmine does the same been told its the door strap needs replaced if thts what its called ive tried tightening it several times before and is just the same.... Quote Link to comment Share on other sites More sharing options...
RobG Posted January 25, 2008 Report Share Posted January 25, 2008 It'll be the check strap, my driver's side has started doing it, but it's still not too bad at the moment.Part numbers for the driver's side are here in post #51. There's also a How To on changing them somewhere, oh yeah, hereHope this helps. Quote Link to comment Share on other sites More sharing options...
Lupo Loopy Posted February 1, 2008 Author Report Share Posted February 1, 2008 It'll be the check strap, my driver's side has started doing it, but it's still not too bad at the moment.Part numbers for the driver's side are here in post #51. There's also a How To on changing them somewhere, oh yeah, hereHope this helps.Thanks for the info on the door straps, I've found out that the tool needed to move the door keeper in is a spline tool, its like a torx but with more lugs. Just need to work out what size! Quote Link to comment Share on other sites More sharing options...
MattTDI Posted February 2, 2008 Report Share Posted February 2, 2008 i tohught my wind nooie wa down to it having no doorcard, well hardly any.. or the fact i have wind deflectors Quote Link to comment Share on other sites More sharing options...
lunalupi Posted February 2, 2008 Report Share Posted February 2, 2008 Thanks for the info on the door straps, I've found out that the tool needed to move the door keeper in is a spline tool, its like a torx but with more lugs. Just need to work out what size!When you do I could do with knowing - need to adjust the catch on mine too Quote Link to comment Share on other sites More sharing options...
Lupo Loopy Posted February 11, 2008 Author Report Share Posted February 11, 2008 When you do I could do with knowing - need to adjust the catch on mine tooHello, It's a spline CRV-8CheersLL Quote Link to comment Share on other sites More sharing options...
lunalupi Posted February 11, 2008 Report Share Posted February 11, 2008 Fabby, thanks Off I go to the local tool shop tomorrow Quote Link to comment Share on other sites More sharing options...
