BridLupo Posted December 20, 2007 Report Share Posted December 20, 2007 I think my rear shoes need replacing. Starting to get a growling noise like metal on metal at the rear and I've never changed them. Car has now done 50K. I've got 4 possible Ferrodo part numbers for the shoes all listed for the 1.4TDi. I think the first number is for ABS.FSB408 - FSB191 - FSB622 - FDB1083Does anyone know for certain which ones I require? Also how much of a job is it to change them. I did my Cinquecento sporting ones once and vowed never again.I'm also going to do the pads at the same time although I have done these before and it was a doddle. However at the time the 1.4TDi wasn't listed in books but after a lot of faffing I found Ferrodo FDB775 did fit. Now however there are listings and they say I need eitherFDB1517 or FDB1312 Quote Link to comment Share on other sites More sharing options...
cardaft Posted December 21, 2007 Report Share Posted December 21, 2007 Could just be a build up of dust in the rear drums, ive had that before.Just take them off, give the shoes and drums a good sanding with sandpaper and put them back on.My TDi has done 47,500 miles and the rear shoes are fine, loads left on them.I had a problem getting discs and pads for the front of mine too, polo MK4 TDi ones are the same and usually listed with motorfactors. Quote Link to comment Share on other sites More sharing options...
BridLupo Posted December 21, 2007 Author Report Share Posted December 21, 2007 Got some shoes. Hopefully they are right but I'll find out when fitting them tomo. Will keep club lupo posted. Cheers Quote Link to comment Share on other sites More sharing options...
Daz_Kez Posted December 21, 2007 Report Share Posted December 21, 2007 i know a lupo 1.4 16v with 102k on the clock running the original shoes since it came off the assembly line, although the idiot thought that lubing them up would help :s so i had to stip them down and give a thourough cleanand a little roughing with some sand paper.... Quote Link to comment Share on other sites More sharing options...
cardaft Posted December 21, 2007 Report Share Posted December 21, 2007 I doubt you need new shoes as i said above, they last and last since they dont really do all that much.Just give them a clean up and they will be as good as new.Its a common problem for them to start making noises when they get ful with dust or rust. Quote Link to comment Share on other sites More sharing options...
mik3y Posted December 22, 2007 Report Share Posted December 22, 2007 I doubt you need new shoes as i said above, they last and last since they dont really do all that much.Just give them a clean up and they will be as good as new.Its a common problem for them to start making noises when they get ful with dust or rust.tut i don't know ... try and help people out Quote Link to comment Share on other sites More sharing options...
BridLupo Posted December 28, 2007 Author Report Share Posted December 28, 2007 Well I took the rear NS wheel off and took the drum off. The shoes look NEW I mean brand spanking. If I hadn't had the car for the past 23k I'd have said they'd just been changed. So left them on. Gave it a blow out with some air. No signs of problems so it could have just been a stone. Also left the pads as upon closer inspection they still have over 5k left on em Quote Link to comment Share on other sites More sharing options...
cardaft Posted December 28, 2007 Report Share Posted December 28, 2007 (edited) Ah i thought they would be Did you just give them a clean up and put them back together?Ive just had my front pads out today, had a sticky brake since the pads were fitted 4K ago, so thought id investigate. All seems to be fine now after i cleaned up the pads and took some of the rust off the calipers.Front pads last around 40-50K usually, obviously it depends on how its been driven, how you drive it, what brand pads it has and what condition the discs are in. I replaced mine at 44K along with the discs, one pad was just down to the metal Edited December 28, 2007 by cardaft Quote Link to comment Share on other sites More sharing options...
one litre wonder ;) Posted December 28, 2007 Report Share Posted December 28, 2007 Front pads last around 40-50K usually, obviously it depends on how its been driveni killed a set in 20k Quote Link to comment Share on other sites More sharing options...
cardaft Posted December 29, 2007 Report Share Posted December 29, 2007 i killed a set in 20k Yes ive had a rethink My TDi lasted till 44K before i replaced them, although they were gone by then.My 1.0 needed new pads at about 27K Quote Link to comment Share on other sites More sharing options...
MrMischief Posted January 6, 2008 Report Share Posted January 6, 2008 Just replaced the wife's front discs & pads at 51k. Pads were very low, not quite at the metal though & the discs were almost at their limit. Ready for fresh fluid in the next service.Easy calipers to work on, very simple.Pedal travel halved now Quote Link to comment Share on other sites More sharing options...
