loopy_lass Posted June 12, 2007 Report Share Posted June 12, 2007 looking to upgrade my front door speakers as one is knackered and just wanted some advice on what you thinks best quality and fit wise. i'm only running the bog standard vw cassette player (run my ipod thro it) and dont wanna fuss with upgrading that or having an amp etc. something nice and simple that sounds good and doesnt peak at low volume. thanks muchly style="vertical-align:middle" emoid=":)" border="0" alt="smile.gif" /> Quote Link to comment Share on other sites More sharing options...
NOCK Posted June 12, 2007 Report Share Posted June 12, 2007 I think VW did an upgrade speaker kit for the Lupo but where you would get one from I don't know. I don't know how good it is either, however I have heard good things about it.Dunno if that's any help, it's just that if you go aftermarket you will probably need an amp I expect.NOCK Quote Link to comment Share on other sites More sharing options...
Silver! Posted June 12, 2007 Report Share Posted June 12, 2007 I put 16cm JBL Pro GTO-6527 speakers in my Arosa on a SEAT Alana CD head unit. £34.00 from caraudiosecurity.com they also come in a slim depth GTO-6527S.Pretty good sound for no amp, you'll need the adaptor rings too. £14.99 from above website too.You may want to look around for a set of mid range onlys as you already have the tweaters mounted in the dash, but as I said theese are pretty good for what is basically a plug and play fitment. You'll also need to change the cable ends to standards blade fitments.Ray Quote Link to comment Share on other sites More sharing options...
NOCK Posted June 12, 2007 Report Share Posted June 12, 2007 I put 16cm JBL Pro GTO-6527 speakers in my Arosa on a SEAT Alana CD head unit. £34.00 from caraudiosecurity.com they also come in a slim depth GTO-6527S.Pretty good sound for no amp, you'll need the adaptor rings too. £14.99 from above website too.You may want to look around for a set of mid range onlys as you already have the tweaters mounted in the dash, but as I said theese are pretty good for what is basically a plug and play fitment. You'll also need to change the cable ends to standards blade fitments.RayAre these louder than the standard loop ones? Also, how easy is it to swap the loop ones for the new ones i.e. are the standard loop ones screwed or riveted 'cus if they are riveted in that that will make them difficult to remove?NOCK Quote Link to comment Share on other sites More sharing options...
Steffro Posted June 12, 2007 Report Share Posted June 12, 2007 Lupo ones are riveted afaik, however drilling them out must be easy. tbh, any speaker will do. Cheaper the better really, anything expensive wont run well off headunit power.Silver - id be careful with the volume on those speakers, they are 2ohm and headunits shouldnt run that low! Play it at high volume and something will blow I reackon, esp on a headunit amp. Quote Link to comment Share on other sites More sharing options...
NOCK Posted June 12, 2007 Report Share Posted June 12, 2007 afaik style="vertical-align:middle" emoid=":confused:" border="0" alt="confused.gif" /> NOCK Quote Link to comment Share on other sites More sharing options...
Steffro Posted June 12, 2007 Report Share Posted June 12, 2007 (edited) as far as I know - it is pretty common on the world of the t'internet afaik style="vertical-align:middle" emoid=":)" border="0" alt="smile.gif" /> Edited June 12, 2007 by Steffro Quote Link to comment Share on other sites More sharing options...
NOCK Posted June 12, 2007 Report Share Posted June 12, 2007 as far as I knowCheers, so do you just drill the rivets then to get them out or...?NOCK Quote Link to comment Share on other sites More sharing options...
LuPo SpOrTX Posted June 15, 2007 Report Share Posted June 15, 2007 Have a look on http://www.caraudiocentre.co.uk/ some good speakers & other ICE. Quote Link to comment Share on other sites More sharing options...
Steffro Posted June 16, 2007 Report Share Posted June 16, 2007 Have a look on http://www.caraudiocentre.co.uk/ some good speakers & other ICE.Not really, they are known for scamming people actually. Quote Link to comment Share on other sites More sharing options...
SC02 FFF Posted June 16, 2007 Report Share Posted June 16, 2007 car audio direct, vgood style="vertical-align:middle" emoid=":)" border="0" alt="smile.gif" /> Quote Link to comment Share on other sites More sharing options...
