emo_gazz Posted August 13, 2006 Report Share Posted August 13, 2006 I know ive asked this before and i dont think anyone answered but i dunno whats wrong. The light only works when i turn it on manually and not when the car doors open. Does anyone know why this might be? Quote Link to comment Share on other sites More sharing options...
cardaft Posted August 13, 2006 Report Share Posted August 13, 2006 And i think i answered you before aswel lol, but here goes, if it works on some doors then its probabbly the switch which i think is in the door catch, if it doesnt work atall with any doors then maybe a fues or a bad connection in the light switch itself. Quote Link to comment Share on other sites More sharing options...
regulator Posted August 13, 2006 Report Share Posted August 13, 2006 not sure if you knew this and sorry if you do but, is the switch set on the right position, the one which activates it when the door opens.If not, maybe a sensor which detects when the door is open and then activates the light?? Quote Link to comment Share on other sites More sharing options...
cardaft Posted August 13, 2006 Report Share Posted August 13, 2006 One way to test the switch on the dorr is to turn on the side lights and see if the buzzer works when you open the door, if it does its not the switch. Quote Link to comment Share on other sites More sharing options...
emo_gazz Posted August 13, 2006 Author Report Share Posted August 13, 2006 yeah its on the middle settin with the little pic of the car with the door open.Ive checked the wires to the light and all seem ok but not the ones runnin to the door. Are they behind that rubber connecting from the car to the door? Quote Link to comment Share on other sites More sharing options...
cardaft Posted August 13, 2006 Report Share Posted August 13, 2006 Im not sure about the wires, the switch went on mine but it was replaced under waranty Quote Link to comment Share on other sites More sharing options...
emo_gazz Posted August 13, 2006 Author Report Share Posted August 13, 2006 (edited) so we dont know then style="vertical-align:middle" emoid=":(" border="0" alt="sad.gif" /> b*gger Edited August 13, 2006 by emo_gazz Quote Link to comment Share on other sites More sharing options...
regulator Posted August 13, 2006 Report Share Posted August 13, 2006 Are they behind that rubber connecting from the car to the door?Yes, the wires are likely to be in the rubber gromet thing in the door. I did see some when I ran the tweeter wires through there. Unless its a sensor, in which case I'm not sure where it would be ... maybe on the clip which holds the door shut?? (sori not sure of the technical word.) Quote Link to comment Share on other sites More sharing options...
emo_gazz Posted August 13, 2006 Author Report Share Posted August 13, 2006 ill have a play around with it tomorrow to see if i can find anything out about this... Quote Link to comment Share on other sites More sharing options...
Robert Posted August 16, 2006 Report Share Posted August 16, 2006 I believe some Arosa's don't have the sensor on the passenger door Quote Link to comment Share on other sites More sharing options...
regulator Posted August 16, 2006 Report Share Posted August 16, 2006 Come to think of it, they could have also used a switch, like some cupboards do so, when they open the light is on but when the door is closed, it pushes the switch breaking the circuit and so switching the light off, but I doubt that this would be so. Quote Link to comment Share on other sites More sharing options...
emo_gazz Posted August 16, 2006 Author Report Share Posted August 16, 2006 Robert i think your right. its been a while since the light worked but i think i can remember that it doesnt work with the passenger side.Still id like to get it to work again. Quote Link to comment Share on other sites More sharing options...
