dj_slipp Posted December 6, 2005 Report Share Posted December 6, 2005 Mine have stopped working when you just hold the indicator stalk up or down and the left one doesn't always work when the indicator stalk is clicked in to position.Somethimes they flash madly, other times just nothing happens. The bulbs all seem to be fine so it must be loose/dirty connections??Anyone else had similar problems and solved it? Cheers. Quote Link to comment Share on other sites More sharing options...
lupogtiboy Posted December 6, 2005 Report Share Posted December 6, 2005 it'll be the hazard switch, has the relay built in, part no 6n0 953 235 b 302 cost is £15.98 inc vat retail Quote Link to comment Share on other sites More sharing options...
1 Litre Screamer Posted December 8, 2005 Report Share Posted December 8, 2005 my loop does exactly the same, the first time it did this was with the left indicator, i thought a bulb had failed when they flashed fast, i think its a dodgy contact in the stalk so i'm going to be digging around with contact cleaner and then a contact lube. see how it goes. Quote Link to comment Share on other sites More sharing options...
dj_slipp Posted December 15, 2005 Author Report Share Posted December 15, 2005 it'll be the hazard switch, has the relay built in, part no 6n0 953 235 b 302 cost is £15.98 inc vat retailThanks for the advice. Are they easy enough to take out and re-fit? Is it a case of removing the switch or the dash around it? Quote Link to comment Share on other sites More sharing options...
Mike_M Posted December 16, 2005 Report Share Posted December 16, 2005 It should be a few screws and clips behind the stereo to release the centre consol trim off the dash and the switch can then be replaced from behind. Quote Link to comment Share on other sites More sharing options...
