scotty g Posted September 13, 2005 Report Share Posted September 13, 2005 hi peaple. Well as it says i have water coming from through speakers. Ive taken lower door card off and the speaker sits on a plastic seat that holds the speaker an inch (approx) from the door.The water seems to be resting in that plastic seat and runs through between the seat and the speaker style="vertical-align:middle" emoid=":(" border="0" alt="sad.gif" /> This happened last week when it pissed it down. It hasnt got to the carpet but i would like to sort this out anyway. style="vertical-align:middle" emoid=":(" border="0" alt="sad.gif" /> HELP style="vertical-align:middle" emoid=":(" border="0" alt="sad.gif" /> Quote Link to comment Share on other sites More sharing options...
Slyclone Posted September 13, 2005 Report Share Posted September 13, 2005 (edited) Has the door membrane been removed? Has the car had any work done on it? Also does the weather strip sit correct on the door and is the window rubber seated correctly? Edited September 13, 2005 by Slyclone Quote Link to comment Share on other sites More sharing options...
scotty g Posted September 13, 2005 Author Report Share Posted September 13, 2005 hi. The rubber strips n seals seem perfect. The sound proofing is stuck solid so dont think thats been removed. Idont know if the car has had any work carried out before my ownership in this area. Quote Link to comment Share on other sites More sharing options...
Funk-star Posted September 13, 2005 Report Share Posted September 13, 2005 take off door card and clean the crap out of the bottom of the door so that you can see through the drain holes, and as if by magic the problem is fixed Quote Link to comment Share on other sites More sharing options...
Slyclone Posted September 13, 2005 Report Share Posted September 13, 2005 hi. The rubber strips n seals seem perfect. The sound proofing is stuck solid so dont think thats been removed. Idont know if the car has had any work carried out before my ownership in this area.<{POST_SNAPBACK}>Its not sound proofing under the door trim, thats a membrane to stop water entering through the door, just make sure that it hasnt been removed before, I cant remember but I know on some cars the speaker mounts on top of the membrane making a water proof gasket around the speaker, if its been removed the person doing this might have cut around the speaker or it might have a crease in it somewhere thats allowing the water in! Also check its the right membrane...is it neatly cut? I think on the loop its slightly 'padded'? Quote Link to comment Share on other sites More sharing options...
scotty g Posted September 13, 2005 Author Report Share Posted September 13, 2005 (edited) Have taken the speaker off and ther is sweet feck all behind it. back of speaker has gone a bit rusty. THATS NOT GOOD Can see the door once speaker is off. No membrane behind that, nothing. Edited September 13, 2005 by scotty g Quote Link to comment Share on other sites More sharing options...
Slyclone Posted September 13, 2005 Report Share Posted September 13, 2005 Ummmm...this is confusing, someone else might have some other opinions about this. I think it is something to do with the membrane but without seeing it I cant help Im afraid Quote Link to comment Share on other sites More sharing options...
BridLupo Posted September 13, 2005 Report Share Posted September 13, 2005 AS previously said the water has to drain away somewhere so look for blocked holes. If the water can't sit still it won't fill the door and come out of the speaker. Quote Link to comment Share on other sites More sharing options...
scotty g Posted September 13, 2005 Author Report Share Posted September 13, 2005 Really should get a digi cam. My go to vw n see what parts are used round this area. see if somethings missing. Quote Link to comment Share on other sites More sharing options...
scotty g Posted September 13, 2005 Author Report Share Posted September 13, 2005 May give that a check bridlupo. Any thing to help. Quote Link to comment Share on other sites More sharing options...
scotty g Posted September 13, 2005 Author Report Share Posted September 13, 2005 Checked the drainage too. thats good as well. Quote Link to comment Share on other sites More sharing options...
Slyclone Posted September 13, 2005 Report Share Posted September 13, 2005 The drainage would have to be well blocked and the door would have to be quite full for water to leak out of the speaker! Quote Link to comment Share on other sites More sharing options...
Funk-star Posted September 13, 2005 Report Share Posted September 13, 2005 The drainage would have to be well blocked and the door would have to be quite full for water to leak out of the speaker!<{POST_SNAPBACK}>Its quite common on MK 2 golfs, that and like mentioned the membrane is not secure. Quote Link to comment Share on other sites More sharing options...
scotty g Posted September 14, 2005 Author Report Share Posted September 14, 2005 Gonna go to vw n check out what the membrane is ment to look like n see if mine been messed wiv. cheers guys style="vertical-align:middle" emoid=":)" border="0" alt="smile.gif" /> Quote Link to comment Share on other sites More sharing options...
