Gearbox issue
LupoPL
 Hello!
I have a gearbox issue .
In this video, I was shifting gears all the time and only once it switched probably on neutral in other case it only trembles slightly.
Also from time to time oil pump keeps pumping.
Oil level is ok, adaptation hasn't done yet.
Thank you all for the reply
Oskar
Can you explain the problem? The video shows the clutch lever.
Any noises? What is it doing that you don't like?
My guess it that you will need to take the gearbox out. Read the gearbox and pedalbox threads...
Welcome to club Lupo :)
pic of car?
Edit: Ah- which model do you have? Is it the 3L?
The model is 3L with automatic gearbox.
Gearbox lever should move to all positions on the video. I changed all the gears twice but it only move once i think on neutral.
Car runs but when trying to shift from first to second gear IT do something like clutch kick and it turn off.
Pics will be soon when IT get's polished :)
I thought it might be a 3L from the sound. We don't have 3L in the UK- don't know the solution. @RAB is the expert, but doesn't visit here much these days.
There are limit sensors on the clutch, and there is some kind of hydraulic pump and pressure reservoir. So sometimes it needs bleeding and/or topping up. And there is some kind of calibration sequence you have to do with diagnostics.
The answer is on this forum as I have read it a few times in the past, but not taken much interest. Have a search, and I'm sure you'll find it. Maybe search through @RAB's previous posts?
