JoshApple Posted February 28, 2022 Report Share Posted February 28, 2022 I have recently had a few issues with my 1.4 16v VW Lupo and its causing it to bog and die. Read the codes and I have had a Manifold pressure sensor come up. Any ideas as to what the problem might be? Quote Link to comment Share on other sites More sharing options...
mk2 Posted February 28, 2022 Report Share Posted February 28, 2022 Can you read any of the live sensor data while it's cold and then again once warmed up and running? Need more info... Quote Link to comment Share on other sites More sharing options...
Rich Posted March 1, 2022 Report Share Posted March 1, 2022 Maybe it's the manifold pressure sensor? I've had this. **** builds up and a cheeky spray of carb cleaner down the throttle as someone revs has cleaned it up enough for it to go away in the past. If that doesn't work then you can always use the carb cleaner to check for air leaks around the inlet manifold. Quote Link to comment Share on other sites More sharing options...
