Moynas GTi polo Posted July 10, 2005 Report Share Posted July 10, 2005 Thanks people for the comments! I did all the work myself taken a while to finish but its done now! got parts from forge, smaco, demon tweeks and a place called rally design (does fords)Its on the original pipe (which is in the inner wing) but i have two feeds to this, and a vent cut in the wing! so plenty of air getin in maybe two much?? Quote Link to comment Share on other sites More sharing options...
tshirt2k Posted July 10, 2005 Report Share Posted July 10, 2005 (edited) Thanks people for the comments! I did all the work myself taken a while to finish but its done now! got parts from forge, smaco, demon tweeks and a place called rally design (does fords)Its on the original pipe (which is in the inner wing) but i have two feeds to this, and a vent cut in the wing! so plenty of air getin in maybe two much??<{POST_SNAPBACK}>Hello mate,Where did you get the bend from ie who made it for you?By the way ,nice Work Edited July 10, 2005 by tshirt2k Quote Link to comment Share on other sites More sharing options...
Red Lup Gti Posted July 10, 2005 Report Share Posted July 10, 2005 saw this today at festival! look's the nut's! Quote Link to comment Share on other sites More sharing options...
payna Posted July 10, 2005 Report Share Posted July 10, 2005 i agree, looks great. did you get any info on the dump valve t-peice tshirt?? Quote Link to comment Share on other sites More sharing options...
tshirt2k Posted July 10, 2005 Report Share Posted July 10, 2005 i agree, looks great. did you get any info on the dump valve t-peice tshirt??<{POST_SNAPBACK}>I'm in two minds what to do now. style="vertical-align:middle" emoid=":confused:" border="0" alt="confused.gif" /> . I was thinking to have a catch tank and recirculate it back into the engine. But not sure.By what people are saying, the small tee is 20mm i just need to confirm the bmc o/d then i can order it.My BMC should be here in a few days, so i want to get all the bits together ready for fitting. Quote Link to comment Share on other sites More sharing options...
payna Posted July 10, 2005 Report Share Posted July 10, 2005 the bmc hosing diameter is definatly 70mm, and the breather hose is give or take 20mm.so that peice you mentioned would be ideal if the smaller t-peice section is 20mm. i was just curious if you had found out if it was? Quote Link to comment Share on other sites More sharing options...
tshirt2k Posted July 10, 2005 Report Share Posted July 10, 2005 That one i posted was from demon tweeks but forge motorsport said they can make them to any size you want. herebut they can make them different sizes with the hose joiners they have70mm hose joinerand 19 mm or 22mm joinerall for £20+vat £5 delivery style="vertical-align:middle" emoid=":shades:" border="0" alt="shades.gif" /> Quote Link to comment Share on other sites More sharing options...
payna Posted July 10, 2005 Report Share Posted July 10, 2005 thats the way to go then mate! ....il be doing mine as soon as i get my samco delivered Quote Link to comment Share on other sites More sharing options...
tshirt2k Posted July 10, 2005 Report Share Posted July 10, 2005 where are you getting your samco from? I'd like red Really to go with the car. And what pipe are you getting? Quote Link to comment Share on other sites More sharing options...
payna Posted July 10, 2005 Report Share Posted July 10, 2005 ive only ordered a 70mm 90deg elbow (in red actually!) just so i can work out what i need as i go along. il also need a coupling hose but i havent ordered that yet.i ordered it from revolution motorstore at gateshead, mainly because its just down the road from me.mine has been on order for about 6 weeks though mate so be prepared for a bit of a wait! Quote Link to comment Share on other sites More sharing options...
tshirt2k Posted July 16, 2005 Report Share Posted July 16, 2005 Did you know you get the elbow in the kit? I have recieved my BMC, have ordered the T Piece and I've just got to get the silicone hose to get it all fitted. oh and I think i'm gonna get a Catch tank too. Quote Link to comment Share on other sites More sharing options...
ArosaMike Posted July 16, 2005 Report Share Posted July 16, 2005 Connecting it to the stock wing vent is a taboo. Its cold air, but the pipe becomes a really small diameter inside. Very restrictive!<{POST_SNAPBACK}>Yeah. It just goes into some bizzare mass of foam in the wing that has no apparent air feed! I also don't know why he's put his oil breather after the filter. It should go ahead of the filter shouldn't it? Quote Link to comment Share on other sites More sharing options...
tshirt2k Posted July 16, 2005 Report Share Posted July 16, 2005 Yeah. It just goes into some bizzare mass of foam in the wing that has no apparent air feed! I also don't know why he's put his oil breather after the filter. It should go ahead of the filter shouldn't it?<{POST_SNAPBACK}>Yep the foam in the wing does nothing for air flow, thats why i removed the pipe, even on the standard box. Makes a major improvement and improves MPG too.It right where he has put the breather. If it went before the filter it would clog it up with oil. Quote Link to comment Share on other sites More sharing options...
payna Posted July 16, 2005 Report Share Posted July 16, 2005 yeah i know mate, ive had my bmc on for nearly a year now, just wanted to tidy things up with samco! - should look pretty good if it all fits snug and symetrical!i picked the samco 90deg elbow today, but havent got my car at the min. think i might just leave it off for a while anyways, till i get a t-peice and the other odds and sods i need to do the breather mod. Quote Link to comment Share on other sites More sharing options...
tshirt2k Posted July 23, 2005 Report Share Posted July 23, 2005 (edited) My T piece arrived on thurs from forge. it slightly long so i cut it down (10mm). border="0" class="linked-image" /> border="0" class="linked-image" />And i managed to fit it all together with a temporary breather connection.But **** me i love the extra power and noise. style="vertical-align:middle" emoid=":wub:" border="0" alt="wub.gif" /> Just got to mod the cover so it fits on. Edited July 23, 2005 by tshirt2k Quote Link to comment Share on other sites More sharing options...
payna Posted July 23, 2005 Report Share Posted July 23, 2005 style="vertical-align:middle" emoid=":D" border="0" alt="biggrin.gif" /> need to put mine back on! but i think il wait till i get all the bit for the breather conection.looks good though mate! how much did it set you back then? Quote Link to comment Share on other sites More sharing options...
Tigz™ Posted July 23, 2005 Author Report Share Posted July 23, 2005 Looks great.All you need now is a nice shiney tank to go with it style="vertical-align:middle" emoid=";)" border="0" alt="wink.gif" /> Quote Link to comment Share on other sites More sharing options...
tshirt2k Posted July 23, 2005 Report Share Posted July 23, 2005 It was £20+vat +delivery as previously stated. Came in 4 days.Brilliant service from Forge.Thinking about the tank, just need to figure out a good place to put it. Quote Link to comment Share on other sites More sharing options...
