1888 Posted December 26, 2020 Report Share Posted December 26, 2020 (edited) My 08 fox does not have a Passenger door lock as in keyhole. Can just buy a lockset and new handle with the hole or do i need more gubbins on the inside? If the later what all do i need to be able to open the door with a key as if to much i may just be cheaper getting a 2nd hand door and new lockset Edited December 27, 2020 by 1888 Quote Link to comment Share on other sites More sharing options...
mk2 Posted December 27, 2020 Report Share Posted December 27, 2020 Breaker's yard is a good place to start... Grab a few vdub lock barrels and you can "recode" the tumblers so you can keep the same key. Quote Link to comment Share on other sites More sharing options...
1888 Posted December 27, 2020 Author Report Share Posted December 27, 2020 7 hours ago, mk2 said: Breaker's yard is a good place to start... Grab a few vdub lock barrels and you can "recode" the tumblers so you can keep the same key. Aye probably the way to go. Ill end up with the whole door if there is one in blue and just buy a lockset. Just started a three week lockdown so this will need to wait just now. I cant see anything obvious but i take the the ignition key is chipped. I only have the Urban Fox 1.2 if it makes a difference. Quote Link to comment Share on other sites More sharing options...
