Darran Posted March 21, 2019 Report Share Posted March 21, 2019 Hi all I been busy going around my lupo I replaced interior bulb and number plate bulbs with LED ones nice and bright so I would like to know if anybody has a link for bright clear bulbs for front lights and reverse bulbsĀ Quote Link to comment Share on other sites More sharing options...
mk2 Posted March 21, 2019 Report Share Posted March 21, 2019 The interior lamp has a dimmer circuit on it. It'll probably not work. When I got one of my SDIs, it had an LED lamp in there and was rubbish. Swapped it for a regular one and it worked again. Tested the LED once out- nothing wrong with it, so I can only suspect that the dimmer driver is designed for regular power hungry filament bulbs. Quote Link to comment Share on other sites More sharing options...
lupogtiboy Posted March 21, 2019 Report Share Posted March 21, 2019 I have an LED interior bulb in mine (a 265 bulb) and it's dims the same as a normal bulb does The front lights are just 501 bulbs, loads available on the net or even halfrauds, reverse lights are 382 bulbs, again loads on the net Quote Link to comment Share on other sites More sharing options...
