jeeprk
Fox interior light
I want to change the bulb but do not have a clue how to get the old bulb out. Do I need to take the whole unit off including the switch?
What type of bulb is it?
Any advice would be much appreciated.
The clear plastic should pop down and then you will see the bulb, take it with you to a shop and buy a new one.
Don't yank the whole unit.
I keep meaning to change out my 9n3 (same unit) one for a MK4 golf one so it has buttons and three lights, not just a cheap sliding unit.
It's a bit expensive to change. I just want to replace the bulb with a led bulb to see if it will be brighter than the stock bulb.
Expense is relative.
Go find a golf in a scrappy and chuck them a fiver for the light
