BioTriffid
P1570 fault immobiliser help?
So today the car run and cut out for 2 - 3 seconds so I put a diagnostic on and the code P1570 immobiliser come up I cleared the code car run fine but then I turned it off and back on it come back with the same problem of cutting out so I took the battery off for 30 minutes it was clear again but has come back again any help possible any fixes I can do will be much appreciated thanks
So the car is running but fine drives ok but pulling up to lights or junction it will. Start to judder and struggle to pull away also the revves get stuck in 2000rpm range but one's it gets up to speed it will run fine again.
That sounds like something else... not immob. Need more info.
Same fault code keeps coming up I'm gonna try another ecu and change a few sensors I'll keep looking into it if it keeps repeating
