mscherryviolet Posted November 21, 2016 Report Share Posted November 21, 2016 Ok so I have been reading loads of things regarding retrimming headliners, the majority of which say to remove the headliner material, but is there anyway I can just use some spray on adhesive and attach the new fabric over the old one? I don't really want to go to all the bother of removing the original headliner fabric, which is in perfectly good nick, I just want to personalise it a little and freshen it up I'm going to be using thin dressmaking fabric if this is possible? Quote Link to comment Share on other sites More sharing options...
JoeyEunos Posted November 22, 2016 Report Share Posted November 22, 2016 10 hours ago, mscherryviolet said: Ok so I have been reading loads of things regarding retrimming headliners, the majority of which say to remove the headliner material, but is there anyway I can just use some spray on adhesive and attach the new fabric over the old one? I don't really want to go to all the bother of removing the original headliner fabric I'd imagine you don't have to remove the old fabric and you probably could just spray contact adhesive and stick new material over it like it's some kind of interiior sticker book, but like everything in life you get out what your prepared to put in. Cutting corners (No pun intended) will probably translate to poor final results Quote Link to comment Share on other sites More sharing options...
mscherryviolet Posted November 22, 2016 Author Report Share Posted November 22, 2016 5 hours ago, JoeyEunos said: I'd imagine you don't have to remove the old fabric and you probably could just spray contact adhesive and stick new material over it like it's some kind of interiior sticker book, but like everything in life you get out what your prepared to put in. Cutting corners (No pun intended) will probably translate to poor final results Hmm I see what you mean, and I'd rather it looked perfect. I was just somehow hoping I wouldn't have to remove it ha. So in that case would I need headliner material? Not just simple dressmaking fabric? Because I believe headliner material is a bit spongy and alot thicker right? Quote Link to comment Share on other sites More sharing options...
Trx 33 Posted December 29, 2016 Report Share Posted December 29, 2016 You cant remove the OE material as i have tried, you will ruin the headlining and make a mess. I put up this fairly comprehensive guide a while back which might help. I also happen to have this headlining up for sale if you don't want the hassle of DIY-ing it 2 Quote Link to comment Share on other sites More sharing options...
