lupo_ro Posted January 4, 2016 Report Share Posted January 4, 2016 (edited) Hello guys! Yesterday, when I start the car outside was -15 degrees C (I am from Romania, here is very cold right now). I started running the car and when I pass 2000 rpm oil light is blinking. I changed oil back in November and it was Castrol 5w40 c3 and since then I haven't no problems . I checked oil level-ok. What do you think about this? Thanks! Edited January 4, 2016 by lupo_ro Quote Link to comment Share on other sites More sharing options...
Skezza Posted January 4, 2016 Report Share Posted January 4, 2016 Possibly the oil pressure switch, although you're using a surprisingly thick oil for your climate. -15 degrees C VW almost certainly recommend 5w30. Does it do it when it's warm, or only when it's cold? I just wonder if your oil pump is struggling...... Quote Link to comment Share on other sites More sharing options...
lupo_ro Posted January 4, 2016 Author Report Share Posted January 4, 2016 No matter if the engine is cold or hot, does the same problem. Over 2000 rpm the oil light blinking Quote Link to comment Share on other sites More sharing options...
Skezza Posted January 4, 2016 Report Share Posted January 4, 2016 Hmm, I reckon it's possibly the oil pressure switch. No leaks in the crank case is there? Quote Link to comment Share on other sites More sharing options...
lupo_ro Posted January 4, 2016 Author Report Share Posted January 4, 2016 No leaks under the car, since yesterday when I parked it. Quote Link to comment Share on other sites More sharing options...
lupo_ro Posted January 4, 2016 Author Report Share Posted January 4, 2016 The car don't feels different. No other problems. I think too the oil pressure switch is the problem. Quote Link to comment Share on other sites More sharing options...
cj1 Posted January 4, 2016 Report Share Posted January 4, 2016 Not been able to get a copy of VCDS or a fault scanner when the light is on? Worth a go a guess, but yes most likely oil pressure switch Quote Link to comment Share on other sites More sharing options...
lupo_ro Posted January 4, 2016 Author Report Share Posted January 4, 2016 (edited) Tomorrow I will mesure the oil pressure inside the engine. It should be around 2 psi at 2000 rpm, am I right? Edited January 4, 2016 by lupo_ro Quote Link to comment Share on other sites More sharing options...
