Interior Light trouble....
Mines doing the same thing. Only works from the driver side. And on the driver side the lights on buzzer doesn't work. I wouldn't use second hand door mechanism's as it's a common lupo fault.
The interior light is so simple build up that it can only be a faulty swtich. there's 3 wires to it: +12v, Ground and Switch Ground. If there's light in it when one door is open, it's the switch, if there's no light in it at all time, it could be a more things, but as this seems, i would go for a new switch, even new parts can be shitty i've found out. I had an issue like this a while ago, and found that a 2nd hand OEM part had longer lifetime than a new aftermarket part
